Changing Fluid in Rear End Questions? - Mustang Evolution
Old 02-28-2012, 06:25 AM   #1
Dkerk8's Avatar
Im looking to try and find out how much rear end fluid i will need to completely drain and refill my rear end. i have a 1989 Mustang gt 5.0. i believe its an 8.8" rear end but im no positive...
Dkerk8 is offline   Reply With Quote
Old 02-28-2012, 10:08 AM   #2
Re: Changing Fluid in Rear End Questions?
it should have a fill plug in it, I believe you fill it until it comes out of the fill plug~ you can remove the cover to drain or you can suck it out. The better way is to remove the cover of course.... but if you dont reseal it good it will leak.
Old 02-28-2012, 10:32 AM   #3
Dkerk8's Avatar
Ok cool thanks...can i just use some high heat permatex to re. Seal it or is it better to just buy a new gasket?..or use both?
Old 02-28-2012, 10:58 AM   #4
stampde's Avatar
the manual says 4.5 pints
but i usually fill till it comes out of the fill hole
2011 GT Auto
Old 02-28-2012, 11:00 AM   #5
deadsp0t's Avatar
++^^ this is correct.
That's unimpressive
Old 02-28-2012, 11:05 AM   #6
Dkerk8's Avatar
Ok thanks...what do you recomend to re seal it cause i want to pull the cover n inspect everything
Old 02-28-2012, 11:14 AM   #7
stampde's Avatar
a cover gasket always works
but i prefer Permetex diff sealer
2011 GT Auto
Old 02-28-2012, 11:16 AM   #8
Dkerk8's Avatar
Ok ya i was thinkin with goin with permatex too
Old 03-20-2012, 10:15 AM   #9
Dkerk8's Avatar
What weight should i use?.. If it makes a difference
75w 90 or 75w 140
Old 03-20-2012, 11:57 AM   #10
make SURE (and recheck it many times) that the area is super clean and free of any crap or oil residue before putting the seal on and the cover plate etc.
Old 03-20-2012, 12:02 PM   #11
Dkerk8's Avatar
Any suggestion on which weight to use?
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 08:46 PM
GT Rear Badge Paint Attempt avengnd 2011-2014 Mustang GT 36 03-01-2012 08:58 AM
v6 modding questions RaysV6 Pre-2005 V6 Mustang 8 02-28-2012 03:28 PM
Tinted tail lights in CALIFORNIA BeasGT 1996-2004 Mustang GT 28 02-28-2012 10:06 AM
Rear Main Seal BigB227 1996-2004 Mustang GT 2 02-27-2012 05:27 PM
03:42 PM
