Any help please.. - Mustang Evolution
Old 01-31-2008, 06:46 PM   #1
Fishers Stang's Avatar
Any help please..
Hey guys, I was looking over the explorer tonight because were going to get 4-8" of snow soon, and I found this small leak under the hood. its on the Pass. side and its not oil. (the filter and plug are behind it).. anyidea's or do I need to go to Ford and let them deal with it?
Charles
Old 01-31-2008, 06:51 PM   #2
MonteCitan's Avatar
Re: Any help please..
you need to replace that seal, the fluid's leaking out of the housing
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-31-2008, 06:54 PM   #3
MonteCitan's Avatar
see attached
that was a common issue even back when I worked on fords haha
its not a huge deal, and not a large job to do either
Old 01-31-2008, 06:57 PM   #4
U know a guess on how much it will cost?
Charles
Old 01-31-2008, 07:57 PM   #5
MonteCitan's Avatar
If I recall correctly, we charged around ~2.5 hours or so, had to pull off the wheel, hub assembly out of the way, pull out the axle and replace the seal, that might be high though I worked at a dealership...
ask around
Old 01-31-2008, 08:27 PM   #6
gesh, thanks man. well i hope it does not lock up or anything cause i cant drive the mustang out in 4-8" of snow.
Charles
Old 01-31-2008, 08:36 PM   #7
MonteCitan's Avatar
It won't lock up, it'd take a LONG time to lose all that fluid, the differential holds a lot more than the housing...
Old 02-01-2008, 08:50 PM   #8
yeah Ford fixed it for me, $150 bucks. they said if it was the axle then it would of been $1500. thanks for the info man
Charles
07:02 PM
