2004 explorer cel light - Mustang Evolution
Closed Thread
Old 06-28-2012, 08:11 PM   #1
Senior Member
dreamstang is unknown around these parts
need some help guys. my explorer 4.0 flex fuel is getting a flashing cel light. i get code :
300. random misfires
303. cylinder 3 misfire
306. cylinder 6 misfire
316. misfire under 1000 rpm
when the light comes on it will flash and the car will misfire really bad. it is relly intermittent. sometime i cn drive all day. other times it will happen more often.
my thoughts are fuel filter as it needs it anyways. iac. and wires which it also needs.
one more thing. this started happening after a tensioner pulley locked up. when the pulley locked up it still ran, but started chugging and shaking relly bad. maybe something came loose. at first glance i didnt see anything obvious.
help please!
dreamstang is offline
Old 06-28-2012, 08:27 PM   #2
Senior Member
Trojan Horse is just getting started.
Re: 2004 explorer cel light
Check your coil(s)? It may have shaken loose a wire or it/they might be failing.
Also, if it has a crank sensor check that too. The shaking may have jarred something loose there.
Trojan Horse is offline
Old 06-28-2012, 08:31 PM   #3
Senior Member
sounds like good places to start. my first thought was a coil cause i thought that they possibly may have shared one. but i think they are on different ones. but i havent got to deep yet. im not that hip to newer ignition systems. thanx. i look into this weekend.
Old 06-28-2012, 08:47 PM   #4
Filibuster
XXSTEVEO66 is unknown around these parts
Im gunna say coil packs...I had the same ”random” issue with my camaro..would run great then sometimes under wot it would miss and flash the eng light..took it to the dealer they told me evap solenoid I listened to them changed it same prob..took it to an f body specialist said cylinder missfire could be anywhere between the coils to the plugs.changed the packs prob fixed.
ps thats the last time I EVER went to the dealer for issues (bout 10yrs ago)
XXSTEVEO66 is offline
Old 06-28-2012, 08:52 PM   #5
Senior Member
I'm pretty sure you can test the "coil packs" if it has them.
What year is your Explorer?
I have a book on my Ranger that goes from 02-05 if it will help.
Old 06-28-2012, 08:56 PM   #6
Senior Member
2004 4.0 flex fuel
i was gonna check ohms. i can probably check all the coils and see if they match maybe? i do have a haynes/chilton for all my vehicles but i havent got one for this as it hasnt been needed yet but definitly time for a purchase.
Old 06-28-2012, 09:14 PM   #7
Senior Member
2004 4.0 flex fuel
My book lists both the pushrod and the SOHC engine, but has nothing on the Flex Fuel.
I did find a coil pack test procedure though. If you need it I can try to scan it in?
Just let me know.
Oh, yeah, be sure to check the wires and plugs on the cylinders with the trouble codes.
It may be a simple wire/plug issue.
Old 06-28-2012, 09:21 PM   #8
Senior Member
Just let me know.
it is sohc. well i definitly wont get to it tonight. so no rush. but sure ill take it until i get a chance to get a book.
thanx man. i did do a quick glance at all the wires before i even pulled the codes. but know that i know the exact one, i can better look.
one more thing. i dont think its related, but you never know. i have been smelling some coolant lately. this started happening some time before my current issue. i have not found any leaks. and it runs at normal temp. it didnt bug me that much before, but i was keeping an eye on it. but i didnt know if something was up with the collant, if it could be faulty sensor readings or something.
Old 06-28-2012, 09:30 PM   #9
Filibuster
Coolant smell maybe ”maybe” water pump goin bad pushin a bit of coolant out of the weep hole?..a small enough amout it evaporates but gives a stink?..
Old 06-28-2012, 09:31 PM   #10
Senior Member
About the coolant.
I have noticed on almost every SOCH/DOCH engine I have been around with the hood open and the engine is hot that I can smell antifreeze. I don't know if it is in the overflow systems or what but it seems to be the norm for most 4,6 & 8 cylinder engines of that configuration that I've seen.
If it is not losing enough to notice I wouldn't think it could cause any problems.
Old 06-28-2012, 09:38 PM   #11
Senior Member
About the coolant.
yeah the level stays the same.
it never worried me to much. i just thought that i would throw that in there. never hurts to have to much facts when trouble shooting.
---------- Post added at 10:38 PM ---------- Previous post was at 10:36 PM ----------
yeah i checked everywhere. cause i fugured it would some kind of leak. but everything is nice and clean.
Old 06-28-2012, 09:48 PM   #12
Filibuster
^that's what she said!..
Old 06-28-2012, 09:51 PM   #13
Senior Member
lol
Old 06-28-2012, 11:00 PM   #14
Senior Member
Ignition Coil Test - Finally!
Name:	Ign Coil Test 4-0 Ford.jpg
Old 06-29-2012, 03:46 AM   #15
Senior Member
Cool. Thanx
Old 06-29-2012, 08:12 AM   #16
Blogger
Blogger
99ford's Avatar
99ford is unknown around these parts
I'm pretty certain it's Crank Case Sensor. In previous experiences with a certain government motors product ( My dads Oldsmobile intrigue) I had that problem occur. It was indeed the crank case sensor. Coil's in my experience on my Mom's Lincoln Aviator 4.6l V8 don't throw out misfires that I recall.
On a side note: I would suggest if you do find the coils to be defective make sure to replace the plugs.
As you will find in 15,000 miles you'll be at it again.
99ford is offline
Old 06-29-2012, 08:21 AM   #17
garbill2003's Avatar
garbill2003 is unknown around these parts
The coolant smell mite be the intake or a headgasket
garbill2003 is offline
Old 06-29-2012, 12:07 PM   #18
Senior Member
I never checked compression or anything. But it has been doing this for a while. And I don't have any smoke in the tail pipe and I don't loose/use oil or coolant out of the norm. Also there is no oil the coolant or coolant in the oil. So hopefully she's good there.
Old 06-29-2012, 01:32 PM   #19
The oil doesn't have to leak into antifreeze or antifreeze into oil they can leak on the outside to
Old 06-29-2012, 01:58 PM   #20
Senior Member
Yeah, no leaks at all though and no smoke. It was a good thought though. Thanx for reply.
---------- Post added at 02:58 PM ---------- Previous post was at 02:57 PM ----------
It would be cool to know what is was though.
Old 06-29-2012, 02:30 PM   #21
Filibuster
If nothin is really leaking then I might think as TH said its common to smell coolant on those vehicles..is the coolant overflow a sealed system?...i.e don't open it when it hot!..lol...maybe it's just some fumes escaping or some jazz like that..
Old 06-29-2012, 06:16 PM   #22
Senior Member
im not sure what is called. there isnt even a radiator cap. you only add coolant to the overlow, which is baffled. so i guess it would be sealed?
---------- Post added at 06:35 PM ---------- Previous post was at 06:18 PM ----------
i didnt even see you post on here earlier. oops. the plugs only have a couple thousand miles on them. i will look into the crank sensor. trojan suspects that to. thanx.
---------- Post added at 07:16 PM ---------- Previous post was at 06:35 PM ----------
ok guys. when the tensioner pulley looked up, i only changed the pulley. the whole tensioner looks like it needs replaced. it is shaking pretty good. will the shaking of the tensioner throw off the crank sensor from the belt not getting a steady tenion?
sorry if im slow on this. i am an old school guy. but the coils are inside of the pack? i have to take the four screws on the corners out and dissamble?
Old 06-29-2012, 07:01 PM   #23
Filibuster
Yeah thats the sealed overflow...not sur if that's what it should be called but way back when I worked at jiffy lube that's what we called it just sayin its hot so you cant pop the cap....uhh the crank sensor I would supose it wouldn't be directly affected by the by the belt tentioner being that it's off of the crank that does all the work anywho...
The coil pack though (many car are different) should just be screwed onto a plate and removal is that easy but no you don't have to take them apart they are one piece..
---------- Post added at 08:01 PM ---------- Previous post was at 07:58 PM ----------
A pick might help of the coil pack/packs...my camaro has 3 each one fires for 2 cylinders..but newer cars (ls motors atleast) have 1 for each cylinder..no idea how the exploders work..
Old 06-29-2012, 07:09 PM   #24
Senior Member
well there are 3 coils for six cylinders. im still not understanding where i should test. and i cant tell by the picture trojan posted, even zoomed in on my ipad.
---------- Post added at 08:09 PM ---------- Previous post was at 08:06 PM ----------
this is what it looks like. i just test from terminal to terminal?
i just remembered why i like my carb. lol
Old 06-29-2012, 07:14 PM   #25
Azure's Avatar
Azure is unknown around these parts
Government Motors... Hehe
Azure is offline
Old 06-29-2012, 07:20 PM   #26
Filibuster
Dude...im as lost as you when it comes to testing them..mine just went bad so I replaced them:/
Where the F is this trojan guy when you need him anyway?...lol
Old 06-29-2012, 07:23 PM   #27
Senior Member
Lol. I can test my single coil. Haha
But ill get back to it. I just found an article for dummies.
Old 06-29-2012, 07:29 PM   #28
Filibuster
I need the book on life for dummies lol..
Old 06-29-2012, 07:31 PM   #29
Azure's Avatar
+4, wait, I can't even do that right.
Azure is offline
Old 06-29-2012, 07:38 PM   #30
Senior Member
lol
---------- Post added at 08:38 PM ---------- Previous post was at 08:37 PM ----------
http://easyautodiagnostics.com/ford_...ck_tests_1.php
Old 06-29-2012, 07:38 PM   #31
Filibuster
Well your futurama avatar is awesome!..i believe phillip j fry is a real character based off of myself
Old 06-29-2012, 07:41 PM   #32
Azure's Avatar
Lol!
Bender is my hero
Azure is offline
Old 06-29-2012, 07:41 PM   #33
Filibuster
lol
Nice well I only have the first.2 tools on the list so im fwacked!..oh wait my dd don't gots foil packs haha..
Old 06-29-2012, 08:10 PM   #34
Blogger
Blogger
99ford's Avatar
lol
Great find!! I like how it says go to test 4, 5, etc.. This is better than the book.
99ford is offline
Old 06-29-2012, 08:23 PM   #35
Azure's Avatar
There was a link within that website for 4.6 COP test too. I always just checked ohms, but will probably give this a shot in the future. Thanks!
http://easyautodiagnostics.com/ford_...ion_ford_1.php
Azure is offline
Closed Thread
04:33 AM
