Trans. swap ? - Mustang Evolution
Old 03-05-2008, 04:46 PM   #1
Trans. swap ?
I've got a 73 F-100 w/ a 302 and a c4 trans. I want to put an AOD in it and was wondering if it will just bolt right in or not.
Z-EATER is offline   Reply With Quote
Old 03-05-2008, 05:17 PM   #2
Re: Trans. swap ?
As long as you get the correct bellhousing and input shaft you'll be fine...might wanna check on the flexplate as well.
The transmission should have no problems itself, just a matter of getting all the pieces inbetween
Old 03-05-2008, 05:39 PM   #3
fast64's Avatar
Re: Trans. swap ?
You might need to get a new slip yoke on the driveshaft, but I'm not sure. Also, you'll need a harness and computer if you go with an AOD-E, but that would probably be more work than its worth in an older truck.
GO BRAVES
Old 03-06-2008, 11:03 PM   #4
Re: Trans. swap ?
Thanx for the info
'04 GT Swap-out automatic trans for 6-speed manual ctogni1 1996-2004 Mustang GT 1 01-14-2010 02:29 AM
Trans swap/rebuild iwannagofast 1996-2004 Mustang GT 2 09-05-2009 01:47 PM
Is it possible to do a v8 swap and keep automtic trans. Freddie75150 Pre-2005 V6 Mustang 9 05-27-2009 12:15 AM
Trans Am GT??? .:DarkEntity:. The Bar 10 09-17-2003 04:17 PM
07:59 AM
