Does premium gas really make a difference? - Mustang Evolution
Old 11-18-2012, 05:41 PM   #1
DerekJohnScott's Avatar
I'm a broke 17 year old with a 1987 gt. Should I really be spending the extra to get premium? It is totally stock and isn't raced.
DerekJohnScott is offline   Reply With Quote
Old 11-18-2012, 05:45 PM   #2
BenGT07's Avatar
I wouldn't spend the money. No need for It unless you are modded and tuned for it. Just make sure you are getting gas from quality places. Gas from Bob's discount filling station is usually a bad idea. Stick to places like Chevron, Shell and BP etc.
In the market for a Fox body...
SOLD: 2007 Performance white GT Premium.
Performance: Eibach lowering kit, SVT wheels, Steeda Camber Casters, Steeda short throw, FRPP 4.10's, Airraid CAI, BBK 62mm TB, Brenspeed Detroit Rockers, Pypes Longtubes with O/R H and Violators.
For fun: Window louvers, 15% tint, Raxiom tinted taillights, J&L Audio sub.
BenGT07 is offline   Reply With Quote
Old 11-24-2012, 12:39 PM   #3
AgentOrange's Avatar
The only change premium gas makes in a vehicle tuned for regular is it decreases your wallet's fuel mileage. I get a little chuckle when I see cars for sale and people advertise "ONLY USED PREMIUM FUEL!!!"
AgentOrange is offline   Reply With Quote
Old 11-24-2012, 12:41 PM   #4
With a tune there is a difference. No clue w/o a tune
Old 11-24-2012, 12:43 PM   #5
deadsp0t's Avatar
With a push rod motor a tune is not a huge deal as you can crank up the timing the old fashioned way with the dizzy to 14* and wake that beast up with some 93
That's unimpressive
Old 11-24-2012, 01:00 PM   #6
Lorraine's driver
ab_mach1's Avatar
^This is what suggest.
It may not increase horsepower, etc. but using good gas with the cleaners, etc. will help keep your fuel system in top shape. Have higher octane gas also will lessen the likelihood of knock/ping when you advance the timing.
Instagram: @ab_mach1
Old 11-26-2012, 03:34 PM   #7
Rosco's Avatar
If you have a high compression car then typically you are required to run premium in order to avoid detonation. Octane has to deal with how much the fuel can be compressed be for it detonates. Your dash should tell you if you need it, usually it says "use premium unleaded fuel only" if that's the case. If your engine has been modded, ie forced induction, block work or aggressive tune may require you to use it. If you don't need to run premium I don't see the point in why you would.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 11-26-2012, 09:24 PM   #8
Yeah mine is bone stock and say to use unleaded fuel only. Nothing about premium.
09:22 AM
