I have a 1974 for f-100 300 6 cylinder, no rado good tires, bad motor? - Mustang Evolution
Old 03-01-2010, 01:45 AM   #1
The truck has a bad motor. It is hard to shift , it had it on the floor where it used to be on the column. no radio nothing. 300 6 cylinder. bad motor. good looking truck and inside looks good. it needs new rubber to keep the doors and windows from ratling. i have 4 rims that come with the 1974 model. I would change the rear end it gets bad gas mileage but will pull a tree down. Should i sell it for 2,250 or spend 5-6 thousand to get it first class. insurance is cheap liability. tag cost me nothing because it had an antique tag. Tags in MS. can run up to $1,200.00 per year. Ususally about $400.00 for a ford mustang about a year old. I am considering getting me a 750-1000 series moror cycle to run errands about Jackson. It cost a lot to live in Jackson MS.
conroy is offline   Reply With Quote
Old 03-01-2010, 01:58 AM   #2
Where im from that truck would only bring $500-$750, considering a salvage yard motor will run u an additional $500.Resell value on these trucks is very low to start with, so not worth fixing up unless it has sentimental value. believe me i own 3 customized models of these trucks and i cant give them away.
dubh is offline   Reply With Quote
Old 03-01-2010, 02:25 AM   #3
Ryn
If you can get $2250 for it you better jump on it, and while you are at it I have A 76 supercab with low milage 460 that you can sell for me for the same price.
Ryn is offline   Reply With Quote
01:08 AM
