89 crown victoria heads + cams swap? - Mustang Evolution
Old 04-09-2010, 03:45 PM   #1
Would the heads + cams of a 89 5.0 mustang (or 5.0 H.O) bolt right up to my 302 5.0?
Sorry for the annoying questions I am just trying to get more of an understanding of my engine, and what I could possibly do to modify it.
jeffery is offline   Reply With Quote
Old 04-09-2010, 04:34 PM   #2
First of all You will not notice a diffence at all by using the Gt-40 heads off a ford explorer which are really called Gt-40P heads.as for the cam dont switch that either, you dont want to put that cam on because fist of all u dont even know if it is going to match up with your engine, second of all it, can be worn out and damaged as is. Take the time to look into what cams will work with your set up, call Crane Cams, comp cams or summit racing, they would be glad to help you.if i were you i would rebuild the engine just to make sure when u do make modifications you dont have to worry about other stuff wearing out or breakin down on you
montrell is offline   Reply With Quote
Old 04-09-2010, 04:41 PM   #3
probably not most of the crown victoria's r non roller motors and require maching to convert them or a set of 500$ lifters as for the heads they will bolt right up just don't bother swapping stock 89 heads there all e7te heads at least get a set of gt40's off of a 5.0 explorer
Kenrik is offline   Reply With Quote
Old 04-09-2010, 05:21 PM   #4
try summit racing they will tell you what you need.or go to there web site and look up anything you might need.www.summitracing.com
Nevada is offline   Reply With Quote
09:33 PM
