How fast are the 2001-2003 VW GTI 1.8t's? - Mustang Evolution
Old 12-14-2011, 04:30 PM   #1
Right now I have a 1992 mustang GT. Is it comparable? I know its only a 4 cylinder car but I want a car that has good pick up and torque.
espowyes15 is offline   Reply With Quote
Old 12-14-2011, 04:41 PM   #2
I've driven both, the 2002 and up 1.8Ts are going to be about as fast stock as a 92 GT. You can install nothing besides a $500 chip in any 1.8T 2000-2005 and it will be noticeably quicker than your current 92 GT.
corren is offline   Reply With Quote
Old 12-14-2011, 05:16 PM   #3
Well, one nice way to find that is to take advantage of a car performance simulator, there you can run several virtual tests, that are for you, not for a magazine driver that maybe does not even weight the same as you for instance.
Run performance tests and decide, try at http://www.nxgtrsim.com
emmett is offline   Reply With Quote
Old 12-14-2011, 06:09 PM   #4
The rule of thumb was that a 2 litre turbo had the same performance as a normally aspirated 3 litre car, which was the reason they were built in Europe. All Turbo car have turbo lag although these days it is fairly minimal.I think you will be pleasantly surprised.
twrgadarn8 is offline   Reply With Quote
Old 12-14-2011, 06:25 PM   #5
About the same as a 3.0V6 NA. Does 8.5secs to 60mph from zero. 155ft lbf at 1,750rpm so it has good low down response around town. about 28mpg. Compare it to your 92 mustang GT that I don't know the stats or specs to
annawan is offline   Reply With Quote
Old 12-14-2011, 06:57 PM   #6
If you want torque, then you must find a Vr6.
conlin is offline   Reply With Quote
11:52 AM
