How to tell if your vacuum transmission modulator is bad on a 1993 mustang? - Mustang Evolution
Old 12-22-2011, 10:15 PM   #1
It has trouble shifting into 1 st and 2 nd but it does shift. It reeves up when you push the throttle to hard. We've tried changing the transmission filter and it helped a little but didn't completely solve the problem. So we think the vacuum is bad or the vacuum hoes is clapped some where. Also, if you have any other suggestion to why its doing all of this, please tell me.
Darren is offline   Reply With Quote
Old 12-22-2011, 11:13 PM   #2
Pull the hose to the modulator and see if it has fluid in it. If so, replace the modulator.
modulators are cheap enough. I would replace it if you don't trust it.
You can pull the vacuum line, put suction on one end and hold your finger over the other end and see if it holds suction. If it does not, then the hose llikely has a crack in it. Replace that hose.
imported_Randolph is offline   Reply With Quote
1993 mustang
11:54 AM
