RUST REMOVAL - Mustang Evolution
Old 02-13-2013, 03:44 AM   #1
bradtaylornator's Avatar
RUST REMOVAL
Anyone ever tried white vinegar to remove rust from a gas tank? Or know any other remedy for rust removal?
bradtaylornator is offline   Reply With Quote
Old 02-17-2013, 09:51 AM   #2
Ubnbit's Avatar
How bad is the rust? Surface rust or full blown pitted rust?
Old 02-17-2013, 01:16 PM   #3
Tyoung68's Avatar
Only way to really get rid of rust is cut it out
Old 02-17-2013, 01:29 PM   #4
v8pony's Avatar
Depends if its just surface rust..pics would help
2002 5spd GT
Feb 2013 Mustang of the Month
Old 02-17-2013, 01:32 PM   #5
Tyoung68's Avatar
Well yeah still have to remove it by sanding so pretty much cutting it out haha
Old 02-17-2013, 01:44 PM   #6
Ubnbit's Avatar
Lol. If its surface rust, there are a lot of things he can do. Get the rust out and use a converter/inhibitor. Depending on where it is. There is a difference in rust and rot. Lol. I agree grind it out. Nawh, coca-cola can even be used to remove rust.
Old 02-18-2013, 02:11 PM   #7
Its surface rust in a motorcycle gas tank I wish I would have took pictures of the tank but trust me it was horrible. What I did was use a battery charger to get the rust out. It actually workd extremely well. All you do is fill the tank up with water and put about a cup of washing soda(not baking soda) in and slosh it around. Then hook up your negative cable directly to the tank, then take a piece of iron rod and connect the positive cable to the piece of iron place the iron in the tank but make sure it not touching the tank. I used a spray paint can cap. I punched the iron through the cap and placed the cap where you put gas in the tank. Then just let it charge for as long as you need while periodically flushing the tank with water and cleaning the iron rod. Ive had mine on the charger since Thursday its a slow process but works good. I also bought some white vinegar and some small bolts and shook that around every 24 hours to help break up the big stuff.
Old 02-18-2013, 02:34 PM   #8
you could probably sand the area (remove all rust) and scuff up every bit of the tank, then repaint with the appropriate paint for a like new look
If you are worried the rust will come back you can get a rust cover paint that will stop it dead in its tracks
Old 02-18-2013, 02:54 PM   #9
Ubnbit's Avatar
Ohhhh you meant from inside a gas tank? Right? Not just surface rust on the outside?
Old 02-18-2013, 03:00 PM   #10
Nope I wish. The outside looks great lol, but the inside looks like its been sitting out in a field for 20 years. Buts it actually coming along really well
Old 02-18-2013, 03:04 PM   #11
Ubnbit's Avatar
Good deal. So in essence, you magnetically charged a rod and the rust from the tank is sticking to the rod?
---------- Post added at 06:04 PM ---------- Previous post was at 06:02 PM ----------
Been nice to have just removed the tank and had it sand blasted inside. A small portable sand blaster would have been great.
---------- Post added at 06:04 PM ---------- Previous post was at 06:04 PM ----------
Old 02-18-2013, 03:13 PM   #12
Yeah I didnt even think about sandblasting until we already had it on a charger lol. so I decided to see if the charging process would work. Im probably going to sandblast as my next step.
Old 02-18-2013, 03:13 PM   #13
tc x 4's Avatar
Mid West and other suppliers sell a kit for it. It's an inhibitor and coating process. I restore harleys and all I do is put a hand full of nuts and a little gas in it. Shake it really good for a good amount of time basically sanding the rust out. Make sure you count the nuts so you get them all out. Nothing more is needed. I've seen the coating they sell come off after a period of time and clog the carb up.
Old 02-18-2013, 03:16 PM   #14
Ubnbit's Avatar
Yeah. I've seen those kits to seal the tank. I've see the ones used for cars in restoration. Let us know how your magnetic process works.
Old 02-18-2013, 03:24 PM   #15
tc x 4's Avatar
Ya I wouldn't recommend the kit totally, the etching chemicals work good, but the coating sux. I'm curious to see how the charger works also, but who wants to wait days when you can do it in an hour.
Old 02-18-2013, 03:26 PM   #16
Ubnbit's Avatar
+1 lol. But def a cool method of rust removal.
12:35 PM
