Z71 - Mustang Evolution
Old 04-07-2013, 12:35 PM   #1
XSlashDashX's Avatar
Z71
So, do I need a flush?
ID:	101146   Click image for larger version
Old 04-07-2013, 12:36 PM   #2
nhcowboy's Avatar
NOT A URINAL DUDE! Lol.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 04-07-2013, 01:03 PM   #3
Ghostedmind's Avatar
Jeeze, luckily mine doesn't look that bad, but I'd say probably so.... are you running on the hot side of the gauge?
LCMC Member
Old 04-07-2013, 01:06 PM   #4
Sadly gauge doesn't work. And I've only had this truck for a little while.
Old 04-07-2013, 01:37 PM   #5
Ah, in that case its better safe than sorry lol
---------- Post added at 02:37 PM ---------- Previous post was at 02:36 PM ----------
and, it may just be me, or the picture, but it looks like the deposits in the coolant system have picked up a bit of rust somewhere....
LCMC Member
Old 04-07-2013, 02:13 PM   #6
Loc: Austin,TX
I'd get a replacement radiator.
Old 04-07-2013, 02:49 PM   #7
How much for a new one?
---------- Post added at 02:49 PM ---------- Previous post was at 02:48 PM ----------
One more thing. I'll wipe down the cap and retake photos.
Old 04-07-2013, 02:50 PM   #8
go to Autozone.com, Autopartswarehouse.com, advance auto etc you can get a pretty good idea there, and there are other places you can find them cheaper
LCMC Member
Old 04-07-2013, 03:03 PM   #9
Termi's Avatar
Replacement radiator is what id do too, cuz that looks pretty bad
Termi is offline   Reply With Quote
Old 04-07-2013, 03:43 PM   #10
Is it a lot of work? Would I need a shop to do it?
Old 04-07-2013, 03:59 PM   #11
definately not, most radiators are really easy to change, the one on my '96 altima was 2 bolts and 4 hoses (top water hose, bottom water hose and 2 trans/oil hoses which ever it was) or something like that
---------- Post added at 04:59 PM ---------- Previous post was at 04:58 PM ----------
what year Z71 is it?
LCMC Member
Old 04-07-2013, 04:09 PM   #12
Whtghost1979's Avatar
Why your at it pull the thermostat completely out ad reinstall the housing without it run a water hose though the top hose and let the bottom drain out to back flush the block out till you get most of the trash out. Before putting a new radiator on it
Whtghost1979 is offline   Reply With Quote
Old 04-07-2013, 04:11 PM   #13
+1
LCMC Member
Old 04-08-2013, 12:21 AM   #14
It's 1998 K1500 with the z71 package. 5.7L Vortec.
Old 04-14-2013, 02:48 PM   #15
Compstall's Avatar
Nah it's all good, put that cap back on.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 04-14-2013, 02:54 PM   #16
It's not me, it's you.
primer2tone's Avatar
Lol!
OP,
Somebody has been running strait water in that truck. I wouldn't swap that radiator just yet. Get yourself an autometer temperature gauge. Flush that **** out but I gotta warn ya. Once you disturb all that crud, your problems are just beginning.
Old 04-14-2013, 04:04 PM   #17
Originally Posted by primer2tone View Post
Lol!
OP,
Yeah, radiator leak. Might as well get a new one?
Old 04-15-2013, 04:12 AM   #18
tc x 4's Avatar
I'd jack the radiator cap up and drive a Ford under it.
Old 04-15-2013, 04:53 AM   #19
Flush that engine out real good before you swap radiators. You don't want any crud that might be in the block to stop up a new radiator.
Old 04-15-2013, 07:54 AM   #20
Are new Radiators pricey? Could I do it myself?
Old 04-15-2013, 08:55 AM   #21
tc x 4's Avatar
They are pricey new, easy swap tho. A radiator shop can dip it in an acid tank and make it look like new.
Old 04-16-2013, 12:38 PM   #22
Anything else I might need to change out radiator? New hoses?
Old 04-16-2013, 12:48 PM   #23
tc x 4's Avatar
I'd spend the $100-$150 at the radiator shop. They can make the one you have good as new. From the looks of it, your whole system needs help, not just the radiator. I'd be willing to bet a new one starts at $300+, and you'll still have that stuff in your heater core & block.
Old 04-16-2013, 01:22 PM   #24
Alright. Thanks. I'll see what I can do. First I have to find a radiator shop.
Old 04-16-2013, 08:00 PM   #25
Compstall's Avatar
$177 at Autozone. Hoses and all, you can do it at home for under $250.
- Brent
Old 04-16-2013, 08:13 PM   #26
I've noticed after driving around and then park it, nothing but water comes out underneath for about a minute. Then it stops. Pretty much nothing left in the radiator except water and some radiator stop leak. >.>
Old 04-17-2013, 05:23 AM   #27
tc x 4's Avatar
Keep it full or you will have big problems. Heads on chevys crack between the cylinders pretty easy when over heated.
Old 04-17-2013, 05:28 AM   #28
tc x 4's Avatar
If It's not done right the first time, he'll be asking how to change his motor. His problems go a lot deeper than the radiator.
Old 04-17-2013, 07:17 AM   #29
Oh yeah, big problem. Would this cause the truck not to start? Takes me a few seconds to start the truck. Like it doesn't want to turn over and when it does, I have to give it some gas.
I'll let it idle for a couple minutes and when I give it gas, it seems like it is having a hard time. Could it be the Fuel Filter?
Old 04-17-2013, 08:34 AM   #30
tc x 4's Avatar
It more than likly needs a tune up and all new filters, judging from the previous owners care of the radiator. To check for a cracked head or blown head gasket, look for water in the oil (will be milky looking) or coming out the exaust.
---------- Post added at 09:34 AM ---------- Previous post was at 09:32 AM ----------
Does the truck use water/antifreze.
Old 04-17-2013, 08:35 AM   #31
Hardly own the truck. Previous owner was a teenager. Any who, changed oil less than 1500 miles ago. No milky looking. And only thing comes out the exhaust is Water.
Old 04-17-2013, 08:44 AM   #32
tc x 4's Avatar
Is there antifreze in it now, or water?
Old 04-17-2013, 09:16 AM   #33
Water, and stop leak. That's it.
Old 04-17-2013, 10:55 AM   #34
tc x 4's Avatar
If It's using water, add antifreze the next time and see if the water coming out the exaust is green. If so, your have a blown head gasket or cracked head. Hopefully It's just condensation.
Old 04-17-2013, 11:35 AM   #35
Should be just condensation. I'll give it a go though. Also gonna stop by a radiator shop and get a quote.
08:02 AM
