Air Condition - Mustang Evolution
Old 04-27-2013, 03:05 PM   #1
Cobra1994's Avatar
Region: Delaware
Air Condition
I have a 1994 Mustang Cobra, my A/C went out. I would like to know beside the air compressor what else do I need to replace?
Cobra1994 is offline   Reply With Quote
Old 04-27-2013, 03:15 PM   #2
Ghostedmind's Avatar
The Compressor, condenser, (and I believe there's something called the canister that kinda acts like a tank? I may be thinking about the condenser though.) and ofc always check the freon first. There may be a couple more things but I believe that's the main parts of the system.
LCMC Member
Old 04-27-2013, 03:52 PM   #3
Cobra1994's Avatar
Region: Delaware
Thanks just want to make sure
Old 04-28-2013, 12:28 AM   #4
Compstall's Avatar
Get it serviced and checked for leaks first. If the pressure is low enough the low side switch won't even kick on the compressor.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 04-28-2013, 12:17 PM   #5
That is true, I forgot to mention. You may not need to replace any major parts. If you lost the vacuum in the system it wont work either, you'd have to get a pro to re-do the vacuum on the system and then recharge it with freon. AND if you lost the vacuum and put freon in on top of that you'll just be wasting your money on the freon because it still won't work.
LCMC Member
Old 04-28-2013, 02:51 PM   #6
Cobra1994's Avatar
Region: Delaware
Thanks we will also check it out.
01:21 PM
