okay guys i reqlly need help - Mustang Evolution
Old 05-16-2013, 08:26 PM   #1
andregayola's Avatar
so i have a 2002 jeep grand Cherokee and today the heat went up like crazy and ten it spewed green liquid all over the place i think it was a valve releasing te pressure from the radiator and the coolant seems not to be going Anywere so my question is what could be the problem??
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 05-16-2013, 08:42 PM   #2
Sbales88's Avatar
Im guessing the thermostats not opening or your water pump went out
Sbales88 is offline   Reply With Quote
Old 05-16-2013, 09:31 PM   #3
blackbeast12's Avatar
Region: Delaware
Im thinking its jealous because you drive your mustang more often!
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 05-16-2013, 10:35 PM   #4
1slosix's Avatar
Just swap out the thermostat... refill with coolant and burp the system. Should be golden. If not check the pump.
carving corners like a boss
Old 05-17-2013, 12:25 AM   #5
i think it could also be the electric fan so ce it's Jeanine at idle
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
02:57 PM
