Rear Gear - Mustang Evolution
Old 05-17-2013, 10:10 PM   #1
Cobra1994's Avatar
Region: Delaware
Rear Gear
I have a 1994 Mustang Cobra 5.0. I would like to know what is the gear ratio that the cobra stock engine came with. Also if I wanted to replace the rear gear, what gear should I go to without adding any modification on the cobra.
Cobra1994 is offline   Reply With Quote
Old 05-20-2013, 04:21 PM   #2
Evil2014GT's Avatar
I believe they come with 3.08s stock. As far as a new gear i would go with either 3.73s or 4.10s. But any gear swap you do will require a tune to adjust the speedo.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 05-20-2013, 05:29 PM   #3
aegischief's Avatar
Used to own a 94 Cobra. They came stock with 3.08 gears. I has 3.73 gears in it when the motor was stock and loved it. To correct the speedo you will need to change the driven gear on the speedo cable. I believe you'll need a 21 tooth gear if memory serves me correctly.
aegischief is offline   Reply With Quote
Old 05-20-2013, 08:26 PM   #4
Cobra1994's Avatar
Region: Delaware
Thanks for the info
---------- Post added at 10:26 PM ---------- Previous post was at 10:26 PM ----------
Thanks for the info
12:51 AM
