b16 honda vs 289 notch race - Mustang Evolution
Old 10-01-2013, 10:20 PM   #1
mike_jay5.0's Avatar
Yesterday I seen a raced with a 302 notch and and a ek b16 civic..... Civic spanked the stang. I figured if this guy built a high revving 289 tall gearing and gutted the car he would spank the civic. How are these 4bangers able to beat these v8 beast
mike_jay5.0 is offline   Reply With Quote
Old 10-01-2013, 10:30 PM   #2
FriedChicken's Avatar
These civics can actually be supped up pretty good. Especially the civic si's. But idk I beat a b18 swap civic 5 speed with my v6 auto. I would love to have have 4 cyl especially a wrx
FriedChicken is offline   Reply With Quote
Old 10-01-2013, 10:49 PM   #3
It was a b16 fully gutted on slicks. Mustang was notch on slicks.... Bad driving maybe?
Old 10-01-2013, 10:53 PM   #4
If it was a 5 speed he probably missed a gear. Don't see how a b16 would beat him unless it was turboed
Old 10-01-2013, 10:54 PM   #5
I also seen a clip of a similar set up.png youtube when I was trying to.gain insight
Old 10-01-2013, 11:00 PM   #6
Identical cars. This civic has a ;20 instead of a b16
Old 10-01-2013, 11:01 PM   #7
9tee7pony's Avatar
I can pretty easily beat a bolt on b20 with my car. I would assume the guy in the notch messed up or the b16 had more done than you knew about.
9tee7pony is offline   Reply With Quote
Old 10-01-2013, 11:07 PM   #8
Civic in the clip had a k20
Old 10-02-2013, 06:01 AM   #9
DustyStang306's Avatar
The Honda can be quick in the 1/4 if done right iv seen lots on b20 vtec N/A builds do mid 12
DustyStang306 is offline   Reply With Quote
Old 10-02-2013, 06:15 AM   #10
Ish416's Avatar
It all comes down to power to weight.
A K20 can make 230whp with just bolt ons.
A B16 can make over 200whp with a bit more work.
Depending on the Civic, a gutted one can weigh less than 2000lbs.
So, assuming the standard 15% drivetrain loss, that could put a K20 Civic at 265hp (crank) with a weight of 2000 lbs, that comes down to a power to weight ratio of 7.54 lbs per hp.
If we take the same car and give it a 200whp B16, again with the standard 15% drivetrain loss, that would put the B16 Civic at 230hp (crank). That would give this car a power to weight of 8.69lbs per hp. That would mean that between this car and a new 5.0, it could be surprisingly close.
A new Mustang GT with 420hp and a weight of 3600lbs only has a power to weight of 8.57lbs per hp.
A stock Notchback Mustang (Third Gen) only made 225hp to the crank and weighed 3200lbs. That's a power to weight of 14.22lbs per hp. So unless that car was making signifigantly more power or was on a serious diet, it was bound to be slow.
It's amazing what a small amount of power can do when it doesn't have to move much weight.
Old 10-02-2013, 07:35 AM   #11
9tee7pony's Avatar
A really low weight can win a lot of races, but if it is for example a mile drag the low power and weight can't overcome the air drag and the high power and weight car will come flying back into the lead.
Old 10-02-2013, 08:20 AM   #12
bigmac3's Avatar
What is a 289 NOTCH?
Having owned a few 289s back in the day I have to say that unless you had a K-coder or did a lot of work to it, they were nothing special compared to todays cars. Hopped up Civics can be pretty quick
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 10-02-2013, 08:42 AM   #13
Notch back with a 289 instead of th 5.0
Old 10-02-2013, 09:10 AM   #14
bigmac3's Avatar
When I hear notchback, I'm thinking 1964-1973, or is this something later? If one has a 302, why would they want a 289? We always went bigger from a 289 (302 for the better heads, 351 for more torque).
Frank
Old 10-02-2013, 09:31 AM   #15
High revving 289 with a light body will utilize horse power. use a tall rear end to compensate for the torque. I seen 289 beat half *** built 351 all day
Old 10-02-2013, 10:22 AM   #16
Lol you can make a 302 or a 351 a high revving motor why would you ever want to build a 289?
Old 10-02-2013, 10:45 AM   #17
bigmac3's Avatar
+1^ Here is a 351 that I built that would turn 7½K all day long. I never got beat by a 289.
Frank
Old 10-02-2013, 12:13 PM   #18
My neighbors has a 289 redlines at 8250 in a 88 notch gutted. Weighs about 2800 lbs. He has raced many 303 and 351. Like I said maybe they are just half assed built
Old 10-02-2013, 12:21 PM   #19
bigmac3's Avatar
But what has he done to it? I guarantee it's far from stock if it's turning 8250.
Frank
Old 10-02-2013, 04:01 PM   #20
Of course I like how it "eats revs" bottom end is horrible but it makes up for it up high in the rpm range
Old 10-03-2013, 05:13 AM   #21
Lol what kind of et is he putting down?
Old 10-03-2013, 06:36 PM   #22
He never pushes the motor. Major sandbagging..
Old 10-03-2013, 07:18 PM   #23
Old 10-03-2013, 07:21 PM   #24
Wth
Old 10-25-2013, 07:19 PM   #25
Jlp06's Avatar
Region: Utah
I was at the race track a while ago and saw a guy with a 90s Honda 4 cylinder, he had gutted it and was on spray. Each race he would totally obliterate bigger Supped up v8s easily. Once he reached the end of the track he would have to push his Honda back because the engine had seized up. His crew had a bunch of crate motors waiting, they would just pull the seized up one out and throw the next one in.
Jlp06 is offline   Reply With Quote
09:28 AM
