94 Mustang Cobra - Mustang Evolution
Old 10-08-2013, 06:18 PM   #1
Cobra1994's Avatar
Region: Delaware
94 Mustang Cobra
My 1994 Mustang Cobra center clock console is not working, anyone has any idea?
Cobra1994 is offline   Reply With Quote
Old 10-10-2013, 08:19 PM   #2
1996mustang's Avatar
Fuse? Not working how exactly
Old 10-11-2013, 04:58 PM   #3
Cobra1994's Avatar
Region: Delaware
The clock light doesn't come on. The console is blank.
Old 10-11-2013, 05:18 PM   #4
Ok check to see if the fuse is blown i believe #8. Also try to see if its connected. Was it working before and how long ago did it die?
Old 10-11-2013, 05:42 PM   #5
Cobra1994's Avatar
Region: Delaware
There is no clock time or lighting on the console. The console is blank.
Old 10-11-2013, 05:49 PM   #6
Check your fuses in the fuse block on the driver side
Old 10-11-2013, 05:58 PM   #7
Here is the fuses
Old 10-11-2013, 05:58 PM   #8
Check fuse 8
Old 10-11-2013, 06:39 PM   #9
Cobra1994's Avatar
Region: Delaware
Thank you I will check the fuse box, fuse #8. It's been several years without the clock, it was kind of strange because when I turn the light knob it would reflect on and off, then it finally went out. My radio and mirrors work only the clock console don't work. But I will check the fuse, thank you for your help.
Old 10-11-2013, 06:51 PM   #10
Cobra1994's Avatar
Region: Delaware
According to the chart you send me, it looks like I have to check not only fuse 8 but 6 too. Because six also control the clock. Hopefully it could be either one of the fuse.
Old 10-13-2013, 05:45 PM   #11
Cobra1994's Avatar
Region: Delaware
I checked both fuses and they look good. I order the light board assembly for the clock, hopefully that will do the trick.
Old 10-13-2013, 05:46 PM   #12
Alright hope it does keep is updated
Old 10-14-2013, 07:09 PM   #13
Cobra1994's Avatar
Region: Delaware
As soon as I get the part, I will let you know the out come.
Old 10-21-2013, 08:16 PM   #14
Cobra1994's Avatar
Region: Delaware
The light board assembly did the trick.
Old 10-21-2013, 10:53 PM   #15
Nice good to know the problem got solved
10:04 AM
