Honda - Mustang Evolution
Old 11-27-2013, 02:46 PM   #1
87LX306's Avatar
Honda
So I picked up this Civic in the condition that you see in the first three pics. Paid $500 for it as is. Turbo kit and piece parts were backyard special to say the least. Solid 1/8 NPT thread to 1/4 barb fitting used to feed the turbo oil with the same heading into the turbo. Thin walled vacuum style hose making up this oil feed line as you can see in pic. Aftermarket fuel regulator just dangling in the motor bay, injectors out of a turbo dsm not wired properly and without inline resistors, idle air control valve wasn't even wired, dohc vtec ecm on a sohc non vtec car. As you can see it was a basket case.
So I started to tear down and see how bad things were underneath. Everything looked good, figured id toss a new timing belt and component kit on it, head gasket as well as the water pump. Clean the block and head up, check for straightness the usual. Figured id get rid of the china bay backyard special turbo kit and components. Return it to more or less stock.
ID:	138601   Click image for larger version
ID:	138603   Click image for larger version
ID:	138605   Click image for larger version
ID:	138608   Click image for larger version
ID:	138610   Click image for larger version
ID:	138612   Click image for larger version
ID:	138615   Click image for larger version
ID:	138617   Click image for larger version
ID:	138619   Click image for larger version
ID:	138621   Click image for larger version
ID:	138623   Click image for larger version
87LX306 is offline   Reply With Quote
Old 11-27-2013, 03:05 PM   #2
ColeJohnson's Avatar
After all the parts and stuff how much did you end up spending going back to stock(and pretty much rebuilding the motor)?
2016 Comp Orange GT (current)
Old 11-27-2013, 03:10 PM   #3
87LX306's Avatar
Traded turbo junk for lots of stock parts off local tuners. Everything I pretty much needed I traded for. So far I have just under a grand should be right around $1300 said and done with brakes and new fluids ect. Motor has under 120k. Hope to trade in on craigslist or sell once I'm done.
Old 11-30-2013, 12:45 AM   #4
Slow4V's Avatar
Good steal
Old 11-30-2013, 01:23 AM   #5
87LX306's Avatar
Originally Posted by Slow4V View Post
Good steal
Thanks. Need to make time to hit the boneyard for a throttle body and im done. Scouring craigslist for one and cant find anything.
Old 12-03-2013, 02:20 AM   #6
tommy d's Avatar
Looks like a clean 3 door ! Should be a fun daily driver if its a 5 speed plus the d16y7 gets good gas milage and very reliable engine
tommy d is offline   Reply With Quote
Old 12-03-2013, 02:25 AM   #7
87LX306's Avatar
Thanks, don't know if I'm keeping it or flipping it for a quick buck.
Just hit the boneyard yesterday and grabbed a TB. She will be running today. Just have to bleed out the brakes and a few other little interior bits popped back into place.
Old 12-03-2013, 11:00 AM   #8
87LX306's Avatar
Well shes running. Now I just have to finish up brakes.
ID:	139506   Click image for larger version
ID:	139509   Click image for larger version
Old 12-03-2013, 04:03 PM   #9
tommy d's Avatar
Dam looks good ! You should have no problem selling that car and make a good profit . clean 3 door civics sell very well in my area even with stock motors
Old 12-04-2013, 12:59 AM   #10
87LX306's Avatar
Got rid of the factory cluster an tossed in a cluster out of a Honda Cr-v. Looks better with this cluster.
Old 12-04-2013, 02:25 PM   #11
87LX306's Avatar
Should be able to pull like 2500 or so for it. What do you all think? I have the side skirt for the drivers side just need to pickup a few clips to put it back on.
ID:	139709   Click image for larger version
12:27 AM
