Need an answer! - Mustang Evolution
Old 12-30-2013, 04:54 PM   #1
HunterNorden's Avatar
Need an answer!
I'm about to install my o/r x. My moms worried that I'll get pulled over. My setup will be 2 chambers with o/r x. Will I have any problems with the law?
2003 Mustang GT Centennial: UPR X, 2 Chambers, SR CAI.
Smoked Headlights/Tail lights, 8k HID
HunterNorden is offline   Reply With Quote
Old 12-30-2013, 04:55 PM   #2
Need an answer!
Does NC have emissions testing? And what exhaust are you running?
Old 12-30-2013, 04:56 PM   #3
I live in nc, I think so but not sure. I know I have a few places to get it inspected and I'm keeping the stock h incase I have any problems
Old 12-30-2013, 04:58 PM   #4
The off road pipe is illegal then, doesn't have cats, is the X pipe the only exhaust mod?
Old 12-30-2013, 04:58 PM   #5
We'll can I get pulled over for it?
Old 12-30-2013, 04:59 PM   #6
Mine had the Same worries but where I live they can't stop you for how loud your exhaust is I'm not sure about your state
Codyty is offline   Reply With Quote
Old 12-30-2013, 05:00 PM   #7
Need an answer!
Not for that unless the exhaust is too loud, cops wouldn't know it's not catted, is that the only exhaust mod? Usually cops won't pull you for exhaust unless it's ridiculous, or the cops an a**. So really the only problem is that the X pipe doesn't have cats, so to pass emissions if NC does have testing, you would need to reinstall the factory H pipe.
Old 12-30-2013, 05:06 PM   #8
Ghostedmind's Avatar
NC does have emisions testing, I just moved from the Goldsboro area. you have to have it tested every year in order to get a new car tag, you can get pulled over and if they decide to look you can get a fine. If you aren't worried about that then just keep the old stuff and put it on when its time for you to renew your car tag. Or if you know a inspector then you should be good
This is unless they have done away with the emissions testing.
LCMC Member
Old 12-30-2013, 05:07 PM   #9
Need an answer!
Yeah, if the cops decide to crawl under and look, your getting a ticket for illegal equipment.
Old 12-30-2013, 05:08 PM   #10
SixBanger's Avatar
Cops don't know if an exhaust system is catted or not. And they aren't going to check either. The biggest issue with exhaust systems are being illegally loud (which is a surprisingly difficult thing to do unless you floor it in second right next to a patrol car).
SixBanger is offline   Reply With Quote
Old 12-30-2013, 05:08 PM   #11
My mufflers are basically flow 40s so I'm guessing it won't be that loud
---------- Post added at 07:08 PM ---------- Previous post was at 07:08 PM ----------
Delta flow*
Old 12-30-2013, 05:09 PM   #12
If its only sound then no worries, I've heard some pretty loud cars around that area. Like they said, just don't floor it in front of a cop.
---------- Post added at 08:09 PM ---------- Previous post was at 08:09 PM ----------
But they do have emissions testing each year.
LCMC Member
Old 12-30-2013, 05:11 PM   #13
So basically, your good with the pipe until testing, then you would need to reinstall the H pipe.
Old 12-30-2013, 05:11 PM   #14
NCDOT: Vehicle Emissions & Safety Inspection
Originally Posted by NCDOT
A NC Vehicle Safety & Emissions Inspection is required annually before the vehicle’s registration can be renewed. An inspection consists of 2 steps:
Step 1, County Requirement
If you live in one of these counties you are required to have an emissions inspection.
Jonston, Wake and Wayne counties are included
County Listing
Step 2, Inspections
There are two parts to your vehicle's inspection.
Vehicle Safety Inspection
The vehicle inspection can be performed at any of the 7,500 licensed inspection stations throughout the state.
Exemptions, the following vehicle types do not need a Safety Inspection:
■Vehicles 35 years old, or older
On-Board Diagnostic (OBD) Emissions Inspection
North Carolina is fighting ozone-forming emissions from gasoline-operated cars and light duty trucks. Inspections are conducted using the vehicle’s On-Board Diagnostic (OBD) system, computerized equipment installed on all new vehicles since 1996.
Exemptions, the following vehicle types do not need an OBD Emissions Inspection:
■Model 1995 vehicles, or older
■Diesel-operated vehicles
■Vehicles licensed under the farmer rate
LCMC Member
Old 12-31-2013, 05:41 AM   #15
ksrumbel's Avatar
Originally Posted by Ghostedmind View Post
So it looks like NC does a OBDII hookup for emissions testing, similar to the county that I live in in PA. Basically, they plug your car in and check for any CEL codes or if anything is pending. If you aren't throwing a code or have pending codes, you are good. To do that, you either need MIL eliminator sir a tuner to turn off your rear O2 sensors. Now, if the emissions testing requires them to do either a visual inspection or a sniffer, them you are screwed.
I have been going catless for about 5 years in a county that requires testing. I have had zero problems with passing because my county just requires a plug in test and I have MIL eliminators. I also have had zero issues with cops regarding how loud my car is, and it is loud. I have shorty headers, o/r x, and magnapacks so it is not quiet. Like I said, zero issues.
ksrumbel is offline   Reply With Quote
Old 12-31-2013, 07:29 AM   #16
Jsvt's Avatar
What county ksrumbel?
Jsvt is offline   Reply With Quote
Old 12-31-2013, 07:46 AM   #17
ksrumbel's Avatar
Berks
Old 12-31-2013, 03:40 PM   #18
IIRC they do have a sniffer, little pipes or sensors they stick into your tailpipes right?
Sent from my mobile device.
LCMC Member
Old 12-31-2013, 04:45 PM   #19
Jsvt's Avatar
Berks
Cumberland here.
Old 12-31-2013, 07:56 PM   #20
ksrumbel's Avatar
Cumberland here.
Yeah I checked your profile after you asked me and saw you are from Mechanicsburg. I'm in Hamburg but moving to California.
I would guess you frequent Carlisle during the summer.
Old 01-01-2014, 06:00 AM   #21
Jsvt's Avatar
You know it. When are you leaving? Shoulda got out before this cold winter lol! We'll have to link up at some point before you hit the road. I was in Philly before I came out here for work and I have to say I like this area quite a bit.
Old 01-01-2014, 07:20 AM   #22
ksrumbel's Avatar
Ill PM you. Don't want to hijack this thread.
04:43 AM
