My car won't start someone help - Mustang Evolution
Old 03-04-2014, 08:12 AM   #1
devilsjara69's Avatar
So my car recently had tho problem I try starting it and it turns over but won't start my battery was dead and not holding voltage after charge so I changed it now it's doing the same thing battery is new what else could it be I need another professional opinion on where to start I think it might be this terrible cold weather in jersey smh
devilsjara69 is offline   Reply With Quote
Old 03-04-2014, 08:29 AM   #2
olds442111's Avatar
Send a message via AIM to olds442111
We are talking about the 4.6 powered car, correct?
White 2014 GT Premium / Blower / Auto Trans / Louisiana
Blue 2016 Sport FX4 Crewcab / Blower coming soon
olds442111 is offline   Reply With Quote
Old 03-04-2014, 08:35 AM   #3
olds442111's Avatar
First thing I would suggest is to read this thread.
Won't start! Before you read the thread, verify the following info: The battery is good, and charged up. The engine spins over fine, just will not start. Is this correct?
Old 03-04-2014, 08:36 AM   #4
Yeah 4.6
Old 03-04-2014, 08:37 AM   #5
And it turns
Old 03-04-2014, 08:46 AM   #6
Which thread am I looking at it just brings me to a page of them
Old 03-04-2014, 08:48 AM   #7
olds442111's Avatar
Listen for the fuel pump to run when the ignition is turned to the run position. Don't try to start it. You can cycle the key after a few seconds of being off and it should run for a few seconds then stop. If you have a friend near you, and are uncertain if youre hearing it or not, remove the gas cap, stick a funnel into the gas throat, and someone puts their ear to the funnel while the other person cycles the key. You need to verify that the pump is coming on. It would be a sort of buzz/ whine sound, only for a few seconds. How many miles are on this car?
Old 03-04-2014, 08:50 AM   #8
olds442111's Avatar
Theres many of the responses on there that need to be read. But we can go through this without that thread. Awaiting to see if the fuel pump is definitely running or not.
Old 03-04-2014, 09:07 AM   #9
There's 96000 on it but I'll check when I get back to jersey I'm in pa at school right now I'm pretty positive it was when I turned the key cause I did listen for it I double check when I get home
Old 03-04-2014, 09:10 AM   #10
olds442111's Avatar
Sending you a PM
Old 03-04-2014, 09:11 AM   #11
Ok
Old 03-04-2014, 09:16 AM   #12
tfalk's Avatar
Check the dash and see if the theft light is blinking. If it is, move the tilt wheel either all the way up or all the way down and try again. Known issue with a wiring harness in the column...
99-122 Bright Atlantic Blue S281 S/C Convertible
11-025 Grabber Blue S302 Convertible
Saleen - Power in the hands of a fool!
tfalk is offline   Reply With Quote
Old 03-04-2014, 09:50 AM   #13
Lombardy's Avatar
Could possibly be that the keys chip is going bad or the ignition part in the steering wheel that recognizes the key, it happened to me and I had to get a new key and new ignition. But after ot worked perfectly fine. Plus check all your connections under the hood make sure none came loose or unplugged.
Lombardy is offline   Reply With Quote
A Mustang that you DO NOT WANT olds442111 General Mustang Discussion 45 03-18-2014 06:34 PM
My feelings after 6 weeks of owning my first American car (long) fastfoal General Mustang Discussion 6 07-31-2013 05:21 PM
Mustang 2 motor swap. Curtiswhitehead 2.3 Mustang 2 07-10-2013 08:06 AM
For Sale: 2013 GHIG 5.0 BUSHGUTS Mustangs for Sale and Wanted 90 04-24-2013 05:35 PM
Car still won't start help!! Black_Sunshine Pre-2005 V6 Mustang 15 08-21-2012 10:41 AM
12:03 AM
