Headlight Restoration with Toothpaste????? - Mustang Evolution
Old 03-31-2014, 01:18 AM   #1
2011 Kona Blue's Avatar
Anyone here ever try removing that nasty yellow oxidation covering their headlights with toothpaste. They got you tube videos showing that toothpaste actually removes the oxidation and makes the lenses nice and clear!
Apparently the toothpaste that has plaque removing additives works best because the oxidation is like plaque. Anyone try this method and what were your results? The you tube videos looked legit and not cutting when the demonstration was being done with the toothpaste trick.
Fact or Crap? Many people swear by this process. Basically, clean off the oxidized headlight lens so its free of dirt and debre. Place two to three lines maybe 3 inches wide on the headlights. Use DA polisher and just move toothpaste around the lens prior to buffing. Turn DA polisher on and move around slowly until oxidation is gone.
Old 04-03-2014, 02:33 AM   #2
Peterzinyou's Avatar
I used Meguiars rubbing compound and elbow grease......and then bought new lenses, lol. Seriously, the rubbing compound should be enough.
Sent from my SM-N900T using Mustang Evolution mobile app
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 04-03-2014, 02:36 AM   #3
FullyAutomatic's Avatar
Region: Mexico
oh it works 100% but after a few days will start to look ****ty again lol
speaking from experience
FullyAutomatic is offline   Reply With Quote
Old 04-03-2014, 02:40 AM   #4
Region: Mexico
just go put some toothpaste and grab a wet rag.... scrub your headlight... wipe dry.. look so clear like brand new... 1 week later looks like crap again
Old 04-03-2014, 03:43 AM   #5
2 Stangz's Avatar
Region: Nevada
Toothpaste has some sort of abrasive material in it, thus being able to remove light oxidation. It's worth a shot, but probably "using the right tool for the right job" would be more beneficial in the long run. A proper lens compound or headlight restoration kit may do the job.
Remember to steadily clean your headlights from there on after so they don't end up nasty looking again. I personally can't stand oxidized headlights, I've got a permanent ceramic coating on mine.
Old 04-03-2014, 05:51 AM   #6
bucko's Avatar
Yea, I'm with those that have posted that it works, but only to have the oxidation return after a few days. The stuff sold on the market formulated to do this usually contain protectants to aid in sun block to help prevent further oxidation.
So, maybe some toothpaste, then some sun tan lotion?
I've also wondered why the aftermarket has not offered a replacement lense with real glass (saftey glass) as an alternative?
Old 04-03-2014, 09:30 AM   #7
GrabberMeBlue's Avatar
I've heard that 4 out of 5 dentists recommend this.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 04-03-2014, 09:44 AM   #8
Adogg's Avatar
^^ hahaha good one!!
Don't hate....... appreciate
Old 04-15-2014, 08:38 AM   #9
My wife used Maguiar's headlight restoration kit and that worked really well...then she traded in that car shortly after. Maybe should have done toothpaste right before going to the dealership hahaha
vadersaysno is offline   Reply With Quote
Old 04-15-2014, 01:34 PM   #10
Send a message via AIM to Destination S19
Rubbing compound.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 04-15-2014, 10:51 PM   #11
samuelsmith's Avatar
Detail Doc.
Old 04-20-2014, 07:04 PM   #12
While you're using the toothpaste on the headlights, make sure to double-check them for cavities.
Old 04-20-2014, 07:11 PM   #13
This thread is awesome and if you want to restore your trim back to black use peanut butter
Old 04-20-2014, 07:29 PM   #14
Peanut butter? That's a new one. I've heard that's the best way to get a dog to be your friend. Haha
Old 04-20-2014, 07:36 PM   #15
I read about it but never tried it
Old 04-20-2014, 07:47 PM   #16
On the car or with the dog? lol
Old 04-21-2014, 12:25 AM   #17
Ha ha ha. Lmao. I gave her a root canal.
Old 04-21-2014, 04:49 AM   #18
Stangholio's Avatar
It's not cheating because "it's your dog".
GHIGitty
Stangholio is offline   Reply With Quote
Old 04-25-2014, 03:27 PM   #19
Do NOT put Detail Doc on your headlights if the sun is out. I learned the hard way.
Old 04-25-2014, 03:32 PM   #20
Wetsand, compound, polish
Old 05-02-2014, 08:38 AM   #21
I'm gonna try this
Sent from my SPH-L710 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 05-02-2014, 10:50 AM   #22
Originally Posted by 19robby2 View Post
I'm gonna try this
Let us on the results
Old 05-05-2014, 12:30 AM   #23
Shockingly enough, it works.
It didn't make them super clear but the difference is there. I'll probably do another coat and upload pictures. Cool cheap little trick
headlight restoration best product? dbroncolish 1996-2004 Mustang GT 8 09-19-2011 04:09 PM
Mother's Headlight Restoration Lastoria24 Mustang Paint, Appearance & Detailing 25 05-11-2011 03:48 AM
Headlight Restoration on my Fox oatburner99 Pictures and Videos 3 07-15-2010 08:08 AM
headlight restoration stang-rookie Pictures and Videos 7 04-05-2006 10:22 PM
headlight restoration red pony V6 Mustang Audio & Video 8 08-29-2005 03:06 PM
04:27 PM
