A/C help - Mustang Evolution
Old 05-21-2014, 09:49 PM   #1
Tyoung68's Avatar
A/C help
Soooo its for my jeep but my problem is that i recharged my A/C and the lines are cold both of them but my car is still blowing hot air any ideas? My car doesn't have a heater control valve so I'm stuck any help will be appreciated!
Old 05-21-2014, 10:57 PM   #2
What do you mean by "doesn't have a heater control valve"?
Old 05-21-2014, 11:10 PM   #3
Tyoung68's Avatar
Like on some cars there a valve that controls the flow to the heater core my jeeps doesn't come with one
Old 05-21-2014, 11:24 PM   #4
Most vehicles have coolant running through the heater core constantly, there is no valve. How it usually works is with a door that blocks off the section that the heater core is in so that none of the air that is circulating through the box can come in contact with it.
Perhaps your problem is with the door not moving into the correct position so that the air passes through the A/C section rather than the heat section.
Old 05-22-2014, 05:02 AM   #5
bucko's Avatar
Sounds like the "blend door" is not working as straybullitt mentions. Is it cool when you first start the Jeep in the morning, then turns warm as the engine has been running for a few minutes?
Some vehicles (early Dodge Trucks) have this common problem. What year/model is your Jeep?
Try googling it (i.e. Jeep blows warm air with AC running) to see if it's a common problem, and to point you into a Jeep forum for further answers.
Old 05-22-2014, 01:52 PM   #6
Tyoung68's Avatar
Well you guys were right. After taking my whole dash out to get to the damn heater box i found a few things the doors were actually out of places and the blend door wasn't plug in all the way. And i have a leak In my ac lines now too one step forward two steps back
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
08:25 PM
