Mavrick drag build - Mustang Evolution
Old 09-21-2014, 10:37 PM   #1
Mavrick drag build
I got a 1976 comet the same thing as a mavrick it's got a 302 in it what 302 parts will work with it it's a factory 302 I'm planning on making a street/strip car anyone got ideas to help me lol
---------- Post added at 12:37 AM ---------- Previous post was at 12:36 AM ----------
Also anyone know where I could get a windshield and drivers door glass?
Codyty is offline   Reply With Quote
Old 09-22-2014, 07:51 AM   #2
Region: Oregon
Well, any 302 Windsor parts will work for it. But, like any 302 Windsor (excluding the BOSS), you are limited to what can be done before outrunning the structural integrity of the block.
If you want to add power, just overhaul the engine you have. New bearings and piston rings. ARP rod bolts and head studs and main bolts. New oil pump and water pump. Add an oil cooler. And get a blow-through carb with a Vortech supercharger.
There is really no point in building a 302 on a factory block. So don't waste your money on forged internals or a turbo. You don't need aftermarket heads or any of that jazz. Just a Vortech and be done.
It will give you a reliable and fun 400hp at the wheels. If you want more, then it's time for a 4-bolt block.
Let me check about the glass, I will get back to you.
RockAuto:
http://www.rockauto.com/catalog/x,ca...,parttype,6512
Windshields.com:
http://www.windshields.com/Mercury_w...placement.html
DavidBoren is offline   Reply With Quote
Old 09-22-2014, 09:25 AM   #3
Would a 351 be a better building platform?
Old 09-22-2014, 09:38 AM   #4
Region: Oregon
Yes, the 351 would be a better choice for building power.
If you wouldn't consider it blasphemy, I would say that an LS motor would be better yet.
Old 09-22-2014, 09:44 AM   #5
See that's the thing I'm trying to stay in a nice build without swapping a lot I know ford to ford I wouldn't have todo a lot of custom work
Old 09-22-2014, 09:47 AM   #6
And not sure but Somone told me this 302 was a BOSS
Old 09-23-2014, 03:31 PM   #7
Region: Oregon
Not unless it was swapped in. The 4-bolt BOSS only existed in 1969-'71, if I remember correctly. I'm sorry I don't know casting numbers for the block or the 4v closed chamber Cleveland heads, and you will have to excuse my laziness because I am not going to look it up right now. Pretty sure Google will tell you the casting numbers in about 12 seconds, though. Then you just have to go check your block and heads.
It would be F!cking sweet if you had a legit BOSS motor, though.
Drag bash london drag strip in ky. This sunday 4/29/12 H.A.W.K At the Track 1 04-30-2012 01:37 AM
Need engine build(er) advice. PureVenom 1979-1995 Mustang GT 22 09-17-2005 11:37 AM
Build a 3.8? FloMasta24 Pre-2005 V6 Mustang 7 03-07-2005 07:32 AM
Supercoupe Build Up Black95GT Pre-2005 V6 Mustang 11 01-03-2004 10:01 AM
build me a system Rellik Mustang Audio & Video 11 10-20-2003 11:42 AM
05:27 AM
