I need some really good advice. - Mustang Evolution
Old 04-28-2015, 09:32 AM   #1
warriormustang's Avatar
I have a 2014 warrior edition mustang. I want to do an engine swap and get about 600 hp to the wheel. Can someone please give me a build that can achieve such. Money isn't the issue.
I've been looking at 5.8L but I don't know if it will fit.
warriormustang is offline   Reply With Quote
Old 04-28-2015, 09:33 AM   #2
Name:	ImageUploadedByMustang Evolution1430235220.598848.jpg
ID:	181282 my car
Old 04-28-2015, 09:35 AM   #3
So, I'm assuming you have a V6? You can achieve 600rwhp pretty easy with the trinity and coyote, even the condor can achieve it...
Adventure till you drop
Old 04-28-2015, 09:39 AM   #4
sid719e's Avatar
If money isn't an issue then trade it in and get a 5.0 and mod that.
sid719e is offline   Reply With Quote
Old 04-28-2015, 10:07 AM   #5
I'm not trading that car in. They only 50 of that edition and I got it while serving over seas.
Old 04-28-2015, 10:19 AM   #6
I'd suggest getting a coyote, but you might have to look into what other parts you'll need to change for the car to handle the engine...
Old 04-28-2015, 10:24 AM   #7
Coyote over the trinity?
Old 04-28-2015, 10:26 AM   #8
You will basically be buying a GT500, if you do a trinity swap, in terms of cost, if you have someone do it for you. It will not be cheap and you will need a lot more parts for the swap than just a full engine...
Old 04-28-2015, 10:46 AM   #9
I'll do the coyote swap then
Old 05-16-2015, 11:01 PM   #10
Compstall's Avatar
You won't do it
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 05-17-2015, 08:49 PM   #11
D1STRRBD's Avatar
If money is not an issue look into the weisco/K1 Technology 351 short block. It will give you 600+ N/A whp no problem and is capable of handling 2000hp with forced induction. They take the coyote motor sleeve, bore and stoke it to a true 351ci and the coyote heads and intake will bolt right up to it they will need port and polished for proper flow. I think the engine build not including port, polish and install is around $15,000 add all supporting features and install your looking at close to $20,000. After it is all done. When you open the hood it will look like any other coyote 5.0. Except you will have a 5.8L 351ci!!! Talk about the ultimate sleeper. Here is the article.
http://www.dragzine.com/tech-stories...er-351-coyote/
D1STRRBD is offline   Reply With Quote
91 mustang running really really rich. Need help.:) Attackthesystem 1979-1995 Mustang GT 1 09-29-2012 01:50 PM
Really really need ac help Nicolosi11480 1979-1995 Mustang GT 16 08-24-2012 06:02 PM
96 3.8l with some bolt ons whats next...? Need some advice please!!! Mavs32 Pre-2005 V6 Mustang 6 02-02-2011 04:56 PM
1996 ford mustang?need some good advice...? deshi General Mustang Discussion 2 03-07-2010 03:43 AM
Need some advice on some realistic numbers from enginebasics ASSEMbler Pre-2005 V6 Mustang 25 11-14-2003 01:44 PM
02:21 AM
