What oil are you using? - Mustang Evolution
Old 08-19-2015, 07:56 PM   #1
Junior Member
ricanracer140's Avatar
Looking to upgrade all the fluids in my 2014 Gt Trac Pack. First engine oil change done at the dealer and the used Amalie 5/50. The engine was nice and quiet. Next one was done with the Ford 5/50 full synthetic and have noticed the random tick. Next the transmission. I was convinced that the BG fluid was a better fluid so I changed it. I think the trains was nothchy and actually worsened. So I just went back to Ford Dual Clutch fluid and added 2 additives and tranny feels good. Rear end fluid Ford stuff. I'm due for oil change so I'm just looking for some feedback. Thanks.
ricanracer140 is offline   Reply With Quote
Old 08-19-2015, 10:26 PM   #2
2011 Kona Blue's Avatar
Do you track race your GT meaning auto cross which is the purpose of the Trac Pak?
Sent from my SAMSUNG-SM-G890A using Mustang Evolution mobile app
Old 08-20-2015, 03:19 AM   #3
Junior Member
No track other than an occasional track day or drag strip. I just drive it hard whenever I get in it. Fl heat is also a point to consider.
Old 08-20-2015, 03:56 AM   #4
Fl does get a but toasty. Lol. Hopefully either Rap or Grabber 5.0 will join in on this one. I have seen similar topics on this about the oil weight 5W50 for the trac pack.
The trac pack Gt and non trac pak Gt both have the identical engine and tight engine specs. The non trac pak is recommend oil weight of 5W 20. The Boss also gets 5W50 weight but like the Boss its designed to be a track car and if someone doesn't auto cross track race it, I can't see the need for 5W50.
Ford assumes that people who buy the trac pack are people who are going to auto cross track race. Since you don't auto cross track race, I can't see why you would use 5W50.
Just use a good quality 5W30 synthetic oil weight and you should be good to go. I would recommend either using, Mobil One Extended Performance (gold cap), Amsoil, Royal Purple or Redline.
Old 08-20-2015, 01:41 PM   #5
I use Rotella T6 5W-40 in everything. My truck and my wife's car because both are in the 120k range and the Mustang is getting it because centrifugal blowers beat the **** out of engine oil and Rotella is designed for that sort of thing.
Also, check Amazon for buying oil, especially if you have Prime. Wal-Mart oil prices (cheapest brick and mortar to buy oil by far) but without having to deal with the soul destroying experience that is going to Wal-Mart.
Old 08-21-2015, 02:03 AM   #6
Junior Member
I used the t6 in my SHO and it definitely worked great quieting down the little valve train noises. I am a fan of staying with the 5W50 as I have always hated the thought of running the 5W20 in my old '11 GT. it's like running tap water
Old 08-21-2015, 05:29 AM   #7
The mega thin oils are recommended for CAFE reasons only. 30 weight oil is plenty thin for even the tightest tolerances and not sure who in the hell thinks running 20 weight is a good idea on a Coyote that can do 7k+ RPM...
Old 08-21-2015, 05:30 AM   #8
Junior Member
I agree ^ that's why I prefer the 5w50
Old 08-21-2015, 05:35 AM   #9
If I ever build an aluminum block 2V screamer that spins to the mid 7k range I may look into going to 50 weight myself but for a 5800rpm shift point... lol no need.
Old 08-21-2015, 04:42 PM   #10
Junior Member
Coyote spins to 7k so I guess 50 is justified
Old 08-21-2015, 04:49 PM   #11
^ with the ability to go over 8.
Pick your poison.
Recon is online now   Reply With Quote
Old 08-21-2015, 04:50 PM   #12
Old 08-21-2015, 06:07 PM   #13
Junior Member
Anyone have input for fluid for the MT82 and the rear end? Id prefer same brand for all 3. Looking for full synthetic fluids with extended interval if possible.
Old 08-21-2015, 06:28 PM   #14
Amsoil in the trans, mobil 1 in the diff. Don't overthink it.
Old 08-21-2015, 07:09 PM   #15
Junior Member
Which Amsoil in tranny?
Sent from my iPad using Tapatalk
Old 08-21-2015, 07:13 PM   #16
Junior Member
I was looking on the Amsoil website and they actually put out a message saying they no longer have a replacement or recommendation for mt82 compatible fluid since the recommended oil is now the dual clutch fluid
Top down oil change using pump extractor blmustang01 2011-2014 Mustang GT 12 08-04-2015 10:02 AM
97 Cobra Using oil 97_Cobrax SVT Mustang 5 05-15-2014 08:21 PM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
What are you using??? crazeflier07 Pre-2005 V6 Mustang 8 03-02-2007 07:34 PM
What kind of computer/mass air set up are you guys using? trickflow5 1979-1995 Mustang GT 8 11-07-2006 11:18 AM
09:42 PM
