Custom car paint - Mustang Evolution
Old 11-30-2015, 03:21 PM   #1
MadyCatz's Avatar
Custom car paint
Well over the past few weeks I have been doing auto body on my daily driver to practice for when I want to do auto body on the mustang I'm getting. Just thought Id share some pictures of my handy work. Enjoy!
ID:	194169   Click image for larger version
ID:	194171   Click image for larger version
MadyCatz is offline   Reply With Quote
Old 11-30-2015, 03:49 PM   #2
Looks nice, good work.
Pick your poison.
Old 11-30-2015, 03:53 PM   #3
MadyCatz's Avatar
Thanks I'll be taking the tape off tomorrow. I have the front bumper mostly prep'd for paint so it'll be done soon. Already finished the hood roof and trunk.
Sent from my Z812 using Mustang Evolution mobile app
Old 11-30-2015, 04:53 PM   #4
007Stang's Avatar
I've been interested in being more hands on with my paint now that I'm approaching 100K miles there are so many tiny nicks in my front bumper I want to repaint the whole thing as touch up would just be ridiculous.
Would you mind sharing how to prep the areas and what your setup consists of?
I'm already an active detailer and love the challenge of removing swirl marks, but paint repair with deep chips is a different story.
007Stang is offline   Reply With Quote
Old 11-30-2015, 05:39 PM   #5
MadyCatz's Avatar
For dings and dents youll need body filler.
For starters never grind a bumper or youll melt it. common sense I know but you'd be surprised how many auto techs do this when they first start out.
Usually For dents on a bumper I would start by getting rid of all the old paint from it. I use my hand to sand it or us a DA sander. After that apply durglass filler onto the dents. Before the duraglass drys make sure to use a file to contour it and get it to feather edge. Next move onto body filler usually people use bondo but there are other products you can use. Lastly apply the correct type of body glaze to the body filler then use a DA to get it to feather the edges like you do with the duraglas and body filler. After that I would use the DA to sand the bumper with 180 grit on the DA or work your way up to 320 from 180 by hand. At this point youll need a scuff pad. Two different types I use to get it like I did on my car. First sand with a RED scuff pad should be 400-450 grit the second pad is a grey pad thats 600 grit but dont use it at this step.. After that wipe it off with a rag then a tack rag. There now your ready for either etching or regular primer. (etching primer is never used on plastic!) After you get primer on it and wait about 45 min or what ever the instructions say on the primer you use sand it with both red then grey scuff pads, then wipe off and tack it. After all that you can finally paint your base coat. There are three types of paint you can spray water based, solvent based, and enamel paint. (enamel paint doesn't require clear coat but you can still use it.) Just use what ever base coat type of paint you desire it doesnt really matter, just be aware of the different ways you have to put on the different types of paint. Next you can move onto the clear coat, this is what makes the paint actually shinny not the base coat. Usually 2 wet coats is enough(wet coat means you apply another coat while its still wet). I wouldnt recommend doing more then 2 wet coats at one time till you get good at spraying clear coat as you have to go a little bit faster with it but it all depends on your spray style. If you get runs you can sand and buff out the clear coat no biggy. Bigest things to worry about is dirt and dust thoroughly clean your work area and car and tack even the material you use to mask the car off with. I personally never ran clear coat but I have ran primer. If you run primer for what ever reason dont panic! Wait about 45 min and you can sand it out lightly if your lucky. 240 then 320 grin then your red and grey scuff pad. So much I could tell about the different types of paints but this was the basics...sorta there's a lot to know. I recommend using solvent based base coat because if you run water based you have to let it cure completely before sanding it. Also if you can afford it there's something called a venturi just plug a air line into it and it has like 2 or more air guns that blow across the paint when you use water based. Lastly NEVR EVER WASH WATERBASED unless you have clear coat on top of it. I made that mistake before lol I don't really know if this helped you, Ill be typing up something about this for people in a more simplified version so stand by for that.
Old 11-30-2015, 05:45 PM   #6
MadyCatz's Avatar
Basic version of what I just said.
1. Get paint off or sand paint if its not too bad.
2. Grind area you wish to apply your body fillers (dont grind on plastic)
3. Sand everything with a DA with 80 then 180 grit or by hand 80- 320 grit
4.scuff with scuff pad red pad (400-450 grit)
5. Prime panel with etching and reg primer or just reg primer (don't use etching on plastic)
6.Scuff with red pad then grey pad (600grit)
7.Spray base coat
8.Spray clear coat
Remember to wipe off then tack before painting and make everything on the car and spray area clean of dust.
Side Note: I have done rust repair the front of my hood rusted through so I had to do two steel patches in the front. Ill upload a pic of it tomorrow but you cant tell I welded and contoured two 18 gauge plates to the front of the car.
If you guys and gals want any info that I might have not made clear in my posts please feel free to pm me or ask in this thread!
Old 12-01-2015, 01:54 PM   #7
MadyCatz's Avatar
Here are three pics of the finished work so far. The front bumper and grille are being replaced and the hood had two steel plates welded to it to stop rust.
ID:	194210   Click image for larger version
New edge custom paint and stripes CowboyLyon Mustang Paint, Appearance & Detailing 5 10-30-2012 04:33 PM
Custom Paint avengnd Mustang Paint, Appearance & Detailing 5 05-12-2012 06:06 PM
Get more power keep warranty and custom paint Dfabian911 Shelby Mustang 6 04-21-2012 10:06 PM
How much would a custom paint job cost? please help? collin The Bar 2 03-10-2010 02:51 AM
Custom Paint AlexJ Mustang Audio & Video 22 12-10-2007 07:03 AM
01:16 AM
