Transmission Help!! - Mustang Evolution
Old 09-25-2016, 11:30 PM   #1
Taylor_SS's Avatar
Transmission Help!!
I know that this isn't mustang related, but it's general transmission knowledge i believe. i will have to post a video of the noise it is makin, but it's almost like a whooshing noise. i own a 2006 Mitsubishi Eclipse 2.4L 5-speed and i had it taken to a trans shop after hearing this noise, and they told me it was the throw out bearing, not the input shaft bearing. so yesterday, me and a buddy replaced the clutch with an exedy high performance clutch, and also replaced the throw out bearing, and put it all back together and it's still making the noise. the noise is only heard when the clutch is out, and goes away when the clutch is pressed it. the sound also speeds up when in first and giving it gas at the same time as you let you the clutch. any idea's, suggestions, help? i thought it was the TOB and clutch because it was slipping right before me and my buddy replaced the clutch. be happy to add any more information if you guys need. please help!
Taylor_SS is offline   Reply With Quote
Old 09-26-2016, 02:01 AM   #2
Revvv's Avatar
Could be a pilot bearing, or an output bearing. It could also be worn gears.
Have you drained the fluid to see if there is any debris or metal flake?
Old 09-30-2016, 09:12 AM   #3
Taylor_SS's Avatar
yeah, we drained the fluid. no metal flakes or shavings. transmission is vibrating if you put your hand on the underside while it's running
Old 09-30-2016, 02:12 PM   #4
Revvv's Avatar
Could be an input bearing.
HOW TO: Changing Transmission Fluid on MT82 Manual Transmission Strange Mud 2011-2014 V6 Mustang 16 10-07-2015 11:23 AM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 04:09 AM
transmission stuck in 3rd gear need help theglory 1979-1995 Mustang GT 18 02-15-2006 11:20 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 05:49 PM
12:22 PM
