02 sensors help - Mustang Evolution
Old 03-18-2009, 05:18 PM   #1
02 sensors help
Hey guys, I have a 2000 gt 4.6 v8, have engine light on, it says on my scanner it is the one closest to engine on drivers side, the same one failed 2 years ago and I got a shop to put it in to get my emissions to pass, I did some digging under the car and discoverd that the connector is broken and some wires are broken, the problem is it is not on the sensor side it is on the car side, the sensor is probably ok, my question is to replace this connector is nearly impossible no room, where do those wires connect up at the top somewhere and i will replace the whole thing, if i dissconect at the sensor i still havent been able to see where they go. any help will be appriciated thank you.
pipeguy is offline   Reply With Quote
Old 03-18-2009, 11:31 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: 02 sensors help
when I was doing my intake manifold swap... I noticed that that wire appears to go to the wiring harness for the motor. There is a huge conglomerate of wires. Basically.... enjoy
Old 03-20-2009, 07:25 PM   #3
Re: 02 sensors help
oh boy this is going to be fun
Old 03-20-2009, 11:32 PM   #4
Region: Iowa
Re: 02 sensors help
precisely... it won't be fun.
Old 03-25-2009, 11:48 AM   #5
Re: 02 sensors help
Go to your Ford Dealership make them put it on maybe expensive but, best thing to do have them do it. If they screw up, you can go back and tell them.
tjzola is offline   Reply With Quote
Old 03-25-2009, 01:59 PM   #6
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: 02 sensors help
usually i would say do the work yourself, but electrical stuff on cars and the vast amount of wires is a pita. i mostly agree with tjzola
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
o2 sensors falconplayer79 Pre-2005 V6 Mustang 5 11-28-2009 08:12 AM
02 sensors help pipeguy 1996-2004 Mustang GT 3 02-10-2009 01:24 PM
O2 sensors lowflyn Pre-2005 V6 Mustang 2 06-21-2005 07:23 PM
o2 Sensors? 19ClearCobra96 Pre-2005 V6 Mustang 3 01-22-2005 09:39 AM
02 sensors 97Stallion Pre-2005 V6 Mustang 1 08-23-2004 06:40 PM
10:13 AM
