Brake pads... - Mustang Evolution
Old 11-22-2004, 09:59 PM   #1
SilverStang96's Avatar
Send a message via AIM to SilverStang96
Question Brake pads...
Real quick question.. Are the brake pads on a 96 v6 the same as a 98 GT ????
SilverStang96 is offline   Reply With Quote
Old 11-22-2004, 10:06 PM   #2
Send a message via AIM to NJStang86
Probably not...
The brake pad sizes differ based on the size of the rotors, and the size of the rotors depends on the size of the wheel.
Speaking with that generalization, I'm assuming the 98 GT had a larger wheel, making it's brake pads larger than that of the 96 v6.
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 11-23-2004, 12:32 AM   #3
Brake pads vary depending on the car normally. Unless the GT and V6 had the same caliper assembly, I would guess they are different
Old 11-23-2004, 07:17 AM   #4
Thanks, I didnt figure they were but i thought i would ask anyway.
Old 11-23-2004, 07:28 AM   #5
I felt dumb asking the question anyway.
Old 11-23-2004, 08:18 AM   #6
Danger Dude's Avatar
That is not a dumb question. Actually here is the low down on the Brake systems. 96 and 98 GT's and V6's have the exact same Brake systems and Calipers. The pads are Identical but they have different part numbers if you go to buy them at ford or some parts stores but they are the same. I have heard they are of a different material but I have yet to seemn actual proof that is true.
In 99 they changed the Calipers to Dual piston PBR's but then again both V6's and GT's got the same calipers!!!!
Old 11-23-2004, 08:23 AM   #7
Send a message via AIM to kaper232 Send a message via Yahoo to kaper232
No need to feel dumb, it was actually a really good question. I am sure there are others that werent sure, but now since you posted your question... They know now.
Never feel dumb when posting, we are all here to learn/help...
And.. Thanks Brother Corey...
kaper232 is offline   Reply With Quote
Old 11-23-2004, 12:27 PM   #8
Hm...thanks for setting me straight...lol
Old 11-23-2004, 12:53 PM   #9
Originally Posted by NJStang86
Probably not...
the rotor size does NOT depend on the size of the wheels
Old 11-23-2004, 02:27 PM   #10
Sue me...
I've heard that in order to use a certain rotor you have to have a certain sized wheel. Maybe I'm wrong....who knows.
Everyone makes mistakes
-Frank-
Old 11-23-2004, 02:30 PM   #11
If you get Cobra Brake calipers and rotors you have to use a 17in rim minimum
Old 11-23-2004, 03:07 PM   #12
Yeh...rotor size does make a difference. You can't put 16 inch rotors and 16 inch rims..
Brake Pads Mustangfan2003 1996-2004 Mustang GT 13 07-15-2008 05:13 PM
brake pads blumustang98 Pre-2005 V6 Mustang 12 06-11-2007 07:32 PM
Need new brake pads WhiteStang99 Pre-2005 V6 Mustang 11 03-03-2006 05:44 PM
brake pads charkelly9 Pre-2005 V6 Mustang 32 11-24-2005 10:59 AM
Brake pads 19ClearCobra96 1996-2004 Mustang GT 2 02-20-2005 04:26 PM
07:40 AM
