help please - Mustang Evolution
Old 03-25-2009, 10:35 AM   #1
help please
hello im kris ,new to the site and i need some help.....i recently bought a 98 gt and have upgraded a few things ,exhaust,reaer end,gears,etc.... heres my problem last night i rinsed the engine off after a mild degreasing,and also added "lucas oil treatment to the motor. when i parked the car it was running great. but after the wash its running like crap....almost like a car would run if someone had put the plug wires on in the wrong firing order.... it idles very very rough and has no more power sounds terrible... can some one please help a guy out with some guidence on where i should start or any ideas on whats wrong with my car
kris
letsdothis661 is offline   Reply With Quote
Old 03-25-2009, 11:03 AM   #2
OsirisGuy's Avatar
Re: help please
I believe someone here had a similar problem. What wound up happening was water seeped into the ignition coils and the car was throwing codes as well. It may be there is water in the ignition wires.
I read the post just yesterday so the thought is kinda' fresh in my mind but I could be very wrong. Someone here will be able to give you a much better answer confirming or accurately placing the problem.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 03-25-2009, 11:35 AM   #3
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: help please
you could start by removing the plug wires and use air to blow dry the terminals and wires. then reinstall with dielectric grease, it will keep water from affecting it later too.
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 03-25-2009, 12:36 PM   #4
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: help please
lol, ya i just read that a couple seconds before this one, water had gotten into the coils i believe
http://www.mustangevolution.com/forum/t105010/
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 03-25-2009, 08:44 PM   #5
upton7's Avatar
Re: help please
ya ask hottcobra i think he knew what happened
Old 03-26-2009, 08:23 AM   #6
Re: help please
yup, water on an engine is a bad idea.. I know there comes a time when the engine is so nasty due to neglect that you just have to do it.. just try to not have to go there again after you get it going good.
Old 03-31-2009, 09:34 PM   #7
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: help please
Water on the engine is fine, really, but never pressure wash an engine. High pressure can force water past the weather pack in the electrical connectors and cause problems. Probably once it all dries out it will work fine again as long as nothing corrodes.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-01-2009, 05:41 PM   #8
Re: help please
Sounds electrical as others stated. It happened to me, and found moisture in distributor, in plug connectors. The advise on using di-electric grease is a must.
Gray Ghost is offline   Reply With Quote
Old 04-02-2009, 08:20 AM   #9
GOStang08's Avatar
Re: help please
I am glad that I read this b/c we were going to rinse out the engine bay this weekend b/c of all the pollen in our area getting in there.
GOStang08 is offline   Reply With Quote
Old 04-02-2009, 08:42 AM   #10
Re: help please
if you hand clean your engine regularly there is no need to use a hose as it wont be dirty at all, just say once a month really good and thats all it takes
07:46 PM
