Check ENGINE light..... - Mustang Evolution
Old 11-30-2004, 07:57 AM   #1
SilverStang96's Avatar
Send a message via AIM to SilverStang96
ALright guys... most of you know i got the new stang, well anyway he has a flo-tech x-pipe on it. the check engine light is on /would this be the best way to go??? MIL Elim. and when your check engine light is on does your engine run in "safe mode"?
SilverStang96 is offline   Reply With Quote
Old 11-30-2004, 09:48 AM   #2
theglory's Avatar
Hey guess what I just found a diy to make you some mil eliminators. Click on linky and go to bottom of page. I think I might even try these for the civic since I cant get rid of that malfunction indicator lamp anyway heres the linky.
http://www.mustangevolution.com/foru...ine=1101229075
Just living out the blessings Gods given me, one mile at a time!
So many Struggles, So many Trials, So many reasons for me to Fall, But I have all Strength, And I have all Power, And I will Bury You!
theglory is offline   Reply With Quote
Old 11-30-2004, 11:36 AM   #3
Ya, those should work fine. That check engine light is quite annoying huh? Mine keeps setting off for other reasons.
Old 11-30-2004, 01:57 PM   #4
theglory's Avatar
Going to buy the stuff for mine at radio shack, this afternoon. Oh yeah maybe it'll fix the vic.
Old 11-30-2004, 08:50 PM   #5
Yes very annoying.. I thought about just putting a piece of tape right there so i wouldnt have to look at it anymore... anytime one of my buddies gets in the car their like "WAIT MAN, dont get on it! Your check engine light is on..."
Pft.. newbies.
"Shut up man I know just hold on."
Old 11-30-2004, 08:50 PM   #6
We shall try this....
Old 11-30-2004, 08:51 PM   #7
You and your DIY projects that always turn out EXTREMELY great.
Old 12-01-2004, 06:04 AM   #8
theglory's Avatar
Well I made it last night will hopefully install this weekend. Well se if it works.
Old 12-01-2004, 07:37 AM   #9
most mil eliminators i see dont work worth a crap.... look into a chip or something.... perhaps its just the brands some guys get (cheap way out)
Old 12-01-2004, 07:47 AM   #10
Danger Dude's Avatar
If the light really bugs you and you have nothignelse wrong with the car just pullout the gauge assembly and pull out the engine light bulb!!! Not that I would personally do it but if you are on a tight budget and cant swing a chip, SpectorV is right MIL eliminators are crap, just pull the bulb !!!
Old 12-01-2004, 08:03 AM   #11
you can do it even more getto just put some black tape over the gauge cluster where the light is
Old 12-01-2004, 08:51 AM   #12
theglory's Avatar
Alright can you guys tell me what a chip is?
Old 12-01-2004, 10:41 AM   #13
a chip alters the processor code for what ever means, it may turn off a cel light or alter the a/f ratio it just changes how the car normally operates via the computer.
Old 12-01-2004, 11:04 AM   #14
Uh...I've done that...
Old 12-01-2004, 11:04 AM   #15
theglory's Avatar
Oh your talking about like a performance chip. Like from jet chip or something. Or is this specifically for altering codes for running no cats?
Old 12-01-2004, 11:09 AM   #16
It's basically the same thing. You can get different things all burned into it.
Old 12-02-2004, 06:13 AM   #17
Black95GT's Avatar
Send a message via AIM to Black95GT
Get a diablo tuners or another tuner, you get change settings and turn off mils
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 12-02-2004, 06:31 AM   #18
theglory's Avatar
Yeah but I've always heard if you dont know what you're doing you can screw up your entire computer, and then you get to pay all kinds of money to get someone to fix it. Am I right or wrong? Or is the diablo really easy to program? Can someone get me a link also to their website, and maybe some generic hp numbers, not for mine for the black 98 gt featured above name:silverstang96 thanks guys.
Old 12-02-2004, 08:11 AM   #19
From what i understand, You call them and tell you exactly what you want to be changed, and they burn the chip just the way you want it... then all you do is install it. Is this correcT?
Old 12-02-2004, 09:20 AM   #20
theglory's Avatar
If it is that would be a good mod for you? I still would like to know some hp numbers, with the mods you have!
Old 08-11-2008, 06:14 PM   #21
Re: Check ENGINE light.....
what chips are av and how are they installed
bigbowl is offline   Reply With Quote
Old 08-11-2008, 06:16 PM   #22
i have a check engine light which i had code low presure caused by antifrezze leaking into my sparkplugs holes
Old 08-11-2008, 07:05 PM   #23
1234's Avatar
So its leaking into the cyclinders
Old 08-11-2008, 07:20 PM   #24
Scut95's Avatar
= bad news......liquids don't compress which = bent connecting rods/possible day light seeking connecting rods
Old 08-11-2008, 07:43 PM   #25
no it leaking into the spark plug holes it is a 4.6
Old 08-11-2008, 07:47 PM   #26
1234's Avatar
Ok so im thinking blown head gasket and bad spark plug tube seals.
OUtside off that nothing makes sense.
Im sure someone will correct me if theres anything i might be missing.
Old 08-11-2008, 07:53 PM   #27
composite intake manifold is cracked have new one ordered
check engine
Check Engine Light - Help! Eeyore General Mustang Discussion 15 04-23-2009 07:26 AM
check engine light on! 1999Stang Pre-2005 V6 Mustang 2 08-09-2008 12:04 PM
Need Help with Check Engine light dch61407 1996-2004 Mustang GT 2 01-30-2008 07:01 PM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
Check engine light donnie Pre-2005 V6 Mustang 1 05-22-2006 02:53 PM
02:38 PM
