where did the hp come from? - Mustang Evolution
Old 11-30-2004, 10:56 AM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
ok i wanted to know what were the changes between the 4.6 from 98 and the 4.6 from 99? and if you had a choice would you but a 94-95 5.0 or a 96-98 4.6? if i buy the 4.6 from 98 how hard would it be to put it in the same power range at the 99+ car?thanks for the help
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 11-30-2004, 12:16 PM   #2
i believe the spilt port intakes were introduced in 99, but i dont know anything about teh 4.6 so ....
Old 11-30-2004, 12:35 PM   #3
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
That's the year of the PI heads and intake (performance improved)
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 12-01-2004, 12:51 PM   #4
so if i get the heads off a 99+ plus the upper intake and the comp i would have a 99+ gt engine? and would this package maybe get me 300 hp. a nice set of heads (open to suggestions) and a nice set of cams (same), upper and lower intake. and all the bolt ons including totally new exhaust. headers, cat free h pipe ect.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 12-01-2004, 01:23 PM   #5
if you put PI intake and heads on a non PI engine you would actually have more power then a 99+ the pre 99 GTs have a higher compression ratio so you would get more NA power but would be more touchy if you decided to boost it.
-Adolf Hitler, 1935
Old 12-01-2004, 04:25 PM   #6
hum how much would i be looking at do you think? this sounds like a cheapish mod, kinda sorta. im going to stay N/A as long as i can hit about 300 hp at the crank. maybe up to 325 ish. thanks guys
Delta Sigma Phi
www.DeltaArmsCo.com
Old 12-01-2004, 04:54 PM   #7
for the PI heads about 5-600 for a decent pair, that have a 3 angle valve job. the intakes would run about 250-450, depending what you get extra on the intake(how ported they are). a new cam is about $300 with the new valve springs, and pushrods. the install will be a pretty penny too. those alone should but you over 300 on a 99+, around 300 pre 99 except the 94-95, then your looking closer to the 99+ range of hp. you will have more torque than the 99+ models though, thats if its a 5.0.
bigpomps is offline   Reply With Quote
Old 12-01-2004, 05:08 PM   #8
u dont use pushrods on a 96+ v8 right? and isnt the install of a cam on a 96+ cam mush easier then one in a 95 5.0? and minus the cam isnt all this stock on a 99+ car? and how much better would the flow of a 24 valve engine be? thanks i kno im asking alot of questions, but thanks for the help
Delta Sigma Phi
www.DeltaArmsCo.com
Old 12-01-2004, 09:04 PM   #9
01mineralgrey6's Avatar
96+ 4.6 motors are OHC not pushrod.
by the 24 valves..do you mean the 05 3v GT motor? i belive they have 2 intake valves and 1 exhaust, im not sure, but they breathe a little better
-Tony
'99 cobra 'vert
Old 12-01-2004, 10:32 PM   #10
97Stallion's Avatar
Actually a combination on the intake, heads and cam on the 99+ GT's gave the increase in hp. So you would need the cams to, to do the swap correctly. The SOHC cam swap is a PITA. You have to remove the front cover to remove the cams on top of the heads, so you can remove the heads. So you might as well replace the cams.
Living one day at a time!
Old 12-02-2004, 06:11 AM   #11
Well, the cams are in the heads from 96 on
-Adolf Hitler, 1935
Old 12-09-2004, 05:55 PM   #12
Send a message via AIM to Acer2428
Yep, just replace the cam while the head is out of the car!
Acer2428 is offline   Reply With Quote
Old 01-03-2005, 05:08 PM   #13
Thumbs up
You will have 300 rwhp if you change the cams as well!
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
12:12 AM
