01 GT rear rotor issues - Mustang Evolution
Old 04-01-2009, 01:47 PM   #1
I am trying to replace my stock rear rotors with a new set of SSBC slotted and drilled rotors. the only issue i am running into is, simply the rotor will not break loose. i have the caliper and the anchor plate removed. is there anything i am missing?
Ride1331 is offline   Reply With Quote
Old 04-01-2009, 02:01 PM   #2
SaleenFiend's Avatar
Re: 01 GT rear rotor issues
use some Kroil/WD40/Penetrate. Let it soak near the hub and studs. Then get a rubber mallot or something softer than the rotor(if you don't want to damage it - if you don't care then use a 5lb mall) and hit the inside of the rotor, pushing it off, do this in a circle or different spots until it comes loose.
Make sure there are no metal retainers on the studs either!
Old 04-01-2009, 02:45 PM   #3
also put down some anti seeze for the new rotor so this issue wont repeat itself.
Old 04-15-2009, 03:59 PM   #4
What are you using this car for? What I am wondering is why you went slotted?
Brake Rotor Concern runvsofthisbull Pre-2005 V6 Mustang 20 03-30-2010 08:01 AM
Roush 13-inch Rear Rotor Replacements? 3ricchu 1996-2004 Mustang GT 2 11-16-2009 07:14 AM
Rotor talk Zim 1979-1995 Mustang GT 17 02-03-2007 09:39 AM
Brake rotor question colinsv6stang Pre-2005 V6 Mustang 5 03-29-2006 09:33 AM
Brakes and Rotor replacement robert0803 Pre-2005 V6 Mustang 11 08-14-2004 11:56 AM
08:55 AM
