Chip - Mustang Evolution
Old 04-01-2009, 05:35 PM   #1
Chip
Has anyone purchased a chip from Jawdropper performnce, off ebay? Their clame is mighty big and price is very low. If it works, it will a hack of a deal.
Gray Ghost is offline   Reply With Quote
Old 04-01-2009, 05:42 PM   #2
upton7's Avatar
Re: Chip
i saw chips on ebay i don't remember the brand but it said like 100 horsepower and 30 miles per gallon so i wouldn't do it cuz that is impossible
Old 04-01-2009, 07:31 PM   #3
hottcobra's Avatar
Re: Chip
if it sounds too good to be true it is
Old 04-01-2009, 07:38 PM   #4
wiarumas's Avatar
Re: Chip
x2
Old 04-02-2009, 07:14 AM   #5
Re: Chip
Thanks for the Info. I thought as much, trying to keep friend from buying
Old 04-02-2009, 08:59 AM   #6
Re: Chip
If it is what I am thinking it is... its not a chip. It is a resistor. You have an IAT (intake air temperature sensor) that determines the temperature of air coming into the vehicle. This tells the car how much gas to use in the mix.
The "chip" as they call it replaces the variable sensor with a static one (a reading that does not change) if you take the sensor out you will see two plugs/wires. One is the power coming to the sensor and the next it the power leaving the sensor, the sensor lets the power through at a rate based on the temperature of the air coming in. So it adjusts the power it allows through. This is what the computer uses to determine how much fuel to use.
The resistor replaces this so it lets a specific amount of power though always, and does not care about the temperature of the air. So you can make the car think its really cold out side which means the air coming into the car is more compressed and more fuel is needed per volume to maintain the correct air and fuel ratio.
So the resistor is generally a 100k ohm or so to make it think its super cold outside so a ton of fuel is used. This doesnt do crap for horse power, it may help torque a bit but its nearly 100% worthless. It also makes your gas mileage horrible and can foul out plugs and your cats.
Simply put dont do it.
Old 04-02-2009, 09:04 AM   #7
Herbstang's Avatar
Re: Chip
would you seriously buy a product from someone who doesn't even know how to spell TRIPLE?
Brandon is correct it's a rip off resistor that can damage your CPU
Do you need a chip? snydermj 2005-2010 Mustang GT 16 09-11-2009 06:54 PM
what chip should i use CCstang2004 Pre-2005 V6 Mustang 17 06-30-2005 10:32 AM
chip Sublime782 Pre-2005 V6 Mustang 11 06-09-2005 02:32 AM
f2 chip ttpancakes Pre-2005 V6 Mustang 3 07-07-2004 10:46 AM
Chip ERICK Pre-2005 V6 Mustang 2 08-08-2003 05:50 AM
03:30 PM
