popping sound drivers front wheel - Mustang Evolution
Old 04-03-2009, 06:41 PM   #1
edross's Avatar
you can hear it when turning one direction to the other or when pushing brake, right before stops, also tire is wearing on the outside. what do you guys think is making this noise?
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 04-03-2009, 07:00 PM   #2
OsirisGuy's Avatar
Re: popping sound drivers front wheel
Let's see Hayne's Manual describes Misc. Noise in the steering:
1) Improper tire pressure (also falls for the outside tire wear).
2) Insufficiently lubricated balljoint or steering linkage
3) Loose or worn steering, steering linkage or suspension components
4) Defective shock absorber
5) Defective wheel bearing
6) Worn or damaged suspension bushings
8) Loose wheel nuts
A few others which just apply to the rear axle
Outside tire wear:
2) Excessive speed in turns
3) Incorrect front end alignment
Sorry I don't know exactly what it can be but that list can be quickly narrowed down to get a few ideas of where to check.
Hope it helps somewhat
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 04-03-2009, 08:02 PM   #3
Cobra GT's Avatar
sounds like a wheel bering, grab the tire and pull it in and out and see how much play is in it.
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 04-04-2009, 04:24 PM   #4
edross's Avatar
tire was @ 24psi , other than that i cant see anything, going to goodyear auto center monday , i hope this doesent get to expensive
Old 04-06-2009, 06:06 PM   #5
edross's Avatar
$1,049.52 what the hell, power steering pump is leaking so its not lubing the rack and pinion assembly properly, they want to replace both and flush the system, that sure is alot of money that i dont have right now, i can handle changing the pump, not sure about the rack and pinion
Old 04-06-2009, 06:13 PM   #6
try to narrow down the sound by getting someone to help, open the hood and wiggle thestrut shaft or watch it as the noise happens see if it pops or moves
Old 04-13-2009, 03:13 PM   #7
monstermustang's Avatar
im having the same problem with my car yet it doesnt do it all the time. i usually only hear it when parking or coming to a stop. the noise didnt occur till after i lowered my car and out caster camber plates on it though. after the install im positive everything was tightened back up and nothing appears to be wrong. im hoping mine wont be expensive either.
monstermustang is offline   Reply With Quote
Old 04-13-2009, 04:21 PM   #8
SaleenFiend's Avatar
I doubt you need both the rack and pump. I would start by replacing the leaky pump. If the problem continues then look further into the Rack assembly.
Old 04-13-2009, 08:02 PM   #9
1234's Avatar
It probably not even the pump. It probably just a hose at the pump.
Old 04-13-2009, 08:07 PM   #10
upton7's Avatar
In my 01 v6 i had a popping when i hit bumps. It was the sway bar end link, it had broken and the broken pieces were hitting each other during bumps. Just something i thought you might want to check.
Old 04-13-2009, 08:13 PM   #11
1234's Avatar
Maybe the strut mount. The ball joints. The reason i say that is my car does the same thing and neither the pump nor the rack leak.
Old 04-18-2009, 03:51 PM   #12
edross's Avatar
sorry i havent responded, computer has been down, i did change the power steering pump, still popping, went to another shop and he thinks i have a bad strut, that makes more sense to me. should i replace with stock or aftermarket?
Old 04-18-2009, 04:02 PM   #13
Sorry, I should have made something clear also previously. The popping noise was probably not coming from the PUMP as you have found. I recommended the Pump due to the leak.
The pop noise can be a random amount of things. What you need to tell the shop is that if you allow them to replace the struts then they must guarantee the noise will stop and not return (unless its another part later).
I recommend that you go back with Bilsteins HD (same as 03/04 Cobra) if you want the best. If not pick up some Mach 1 struts. They are great struts.
Old 04-18-2009, 07:06 PM   #14
MonteCitan's Avatar
Could be a strut.. however, something else to check..
When I was a ford tech, we had a COMMON problem with the GTs - the steering rack mount - namely the sleeve that covers the exposed areas of the bolt that goes through the frame tended to creak, our solution was to remove the bolt on the affected side, remove the sleeve, apply some dielectric grease to the ends of the sleeve, reinstall everything then retorque the bolts to spec
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-12-2009, 08:31 AM   #15
edross's Avatar
changed the pump, changed the struts and shocks to monroe sensatracs, changed the hub & bearing assembly, still popping, so i go to another shop this morning and 15 minutes later my car is fixed, so what was it? subframe bolts, tighten all the bolts with a impact wrench and that was it, no sound at all, on top of that the man didnt even charge me, i feel so much better now that my car is fixed, whoo whoo i will be buying a impact wrench, thanks guys
Old 06-21-2009, 10:45 PM   #16
occhopperman27's Avatar
My car does it in the winter in the parking lot after it sits, and back it out and turn, it makes a load popin noise, summer time doesn't happen not sure what it is...
occhopperman27 is offline   Reply With Quote
front wheel bearings 98mustang2007 1996-2004 Mustang GT 1 08-20-2010 10:19 AM
popping noise??? girlandherstang Pre-2005 V6 Mustang 8 06-28-2008 10:20 AM
Front Wheel Bearing Replacement 00vertstang Pre-2005 V6 Mustang 3 03-24-2007 09:42 AM
popping the doors!!!!! fast64 Pictures and Videos 9 10-28-2004 03:56 AM
Whats that Popping? bluemustang The Bar 11 10-18-2004 09:03 PM
08:04 PM
