What spark plugs should I go with? - Mustang Evolution
Old 04-07-2009, 07:15 PM   #1
My 00 GT has about 85,000 miles and I want to change out the spark plugs. What plugs do you all recommend? I'd like to purchase them online if possible; just to make it easier and usually its cheaper
Also do they usually come pre-gapped?
Thanks
Frogleg is offline   Reply With Quote
Old 04-07-2009, 08:33 PM   #2
Re: What spark plugs should I go with?
OEM ford gaped correctly to specifications, thats all you need. Put a little bit of anti seeze on them (very little) and tq to stock specs and your good to go.
they usually come pre gapped but its ALWAYS good to double check
Old 04-07-2009, 11:08 PM   #3
OsirisGuy's Avatar
For Ford a lot of guys here either go with Motorcraft or Autolite, which, either are probably the best for the car.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 04-07-2009, 11:27 PM   #4
So I should stay away from the Iridium / Platinum double tip type of stuff?
Old 04-08-2009, 07:42 AM   #5
no real need, copper is fine it may wear out sooner but... its a good opportunity to check the cylinders to see if all is well anyway~
your factory plugs may not have been cooper though so use what ever ford put in from the factory.
Old 04-08-2009, 09:04 AM   #6
Cobra GT's Avatar
Bump on the anti-seize, I would use the Iridium / Platinum if you can afford them.
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 04-08-2009, 09:15 AM   #7
I'm a fan of the NGK coppers myself. You should be able to find them in the heat range for a GT. I know my stock plug was TR55's, I'm not sure what your plug would be off hand.
Old 04-08-2009, 10:34 AM   #8
denso makes a pretty good plug too.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 04-11-2009, 12:07 AM   #9
im going to try the ngk iridums for my car, they have a finer center electrode than the autolite iridium plugs for an easier spark, but if it was me i wouldnt run anything less than stock materials. im assuming platinum or iridium for your vehicle.
less than stock engine, not running right, 40 series flows, steeda triax shifter
96cobra is offline   Reply With Quote
Old 04-11-2009, 05:45 PM   #10
How would I know what the stock materials are on the spark plugs without taking them out? Didn't see anything in the owners manual.
Old 04-11-2009, 07:02 PM   #11
upton7's Avatar
just get some motorcraft plugs and u won't have to worry about it
Old 04-11-2009, 07:25 PM   #12
bbunt302's Avatar
Motorcraft or Autolite is the way to go. Autolite manufactures the Motorcraft plugs, so they are the same either way. When you buy the platinum/iridium/expensive coppers, all you are getting is a more expensive and heavily marketed plug. They are a waste. Yes, they are more durable, but when you consider the price difference, you are losing money.
Copper is a better conductor than either platinum or iridium. You will get a stronger spark with a copper plug.
The platinum/iridium plugs also produce a thinner, more condensed spark. This can cause problems for two reasons:
#1) If that thin strip is fouled, the plug is garbage. The copper plugs produce a much wider spark that requires more of the plug to be fouled before you have to throw them in the trash.
#2) In high horsepower applications, you're going to want to run on the safe side of the A/F ratio. Because of the thinner spark of platinum/iridium plugs, they are more likely to suffer from spark blowout when extra fuel is present.
Scary stuff.
Old 04-11-2009, 07:37 PM   #13
I use Bosch Platinum Series II plugs. Always worked good for me in the past and the present.
19Delta is offline   Reply With Quote
Old 04-12-2009, 08:26 PM   #14
it should of been in the owners manual, bu you can go to orielly's and they can tell you what materials came with it
Old 04-13-2009, 10:07 PM   #15
silverstangboy's Avatar
it doesn't matter..... cheap plugs replaced more often will be better for the car than any other method when talking power and running condition of the car.
93 mustang notch
~450hp 331 stroker - Sold
Old 04-13-2009, 10:24 PM   #16
your iridium plugs have less resistance, meaning a stronger spark, meaning better throttle responce and power output. the materials are going to be stronger than your copper materials
Old 04-14-2009, 05:12 AM   #17
bbunt302's Avatar
Iridium plugs do not have a stronger spark than copper plugs. Copper is a more conductive material.
Scary stuff.
Old 04-14-2009, 08:17 AM   #18
Herbstang's Avatar
+ 1
The more expensive the plug, the more platinum (double/triple coated) or iridium is usually used in the plug. A thin coating of these precious metals will not fair as well as a thicker, so in general, you won't want to go the cheap route, as it would be better to just use good old copper for your maximum value.
However, in general, the standard copper plug does not reduce quenching like many of the platinum and iridium plugs can. With this said, technology has opened copper type plugs to the similar benefits of the fine electrode using various configurations and shapes. This is where the specialty plug comes in, such as the U-groove or Splitfire.
Old 04-14-2009, 08:18 AM   #19
speaking of Iridium plugs in my car for about a year now, Autolite XP, so far so good.
Old 04-14-2009, 12:51 PM   #20
Wow, I wasn't expecting all the responses but thanks!
I am going to end up going with the NGK TR55 (.054 Gap)
Thanks for all the help.
I took a look at the engine this weekend, it looks like they are held on by a small screw. Is that right?
Also does anyone know the specified torque to put the plugs back in?
Thanks
Old 04-14-2009, 04:41 PM   #21
OsirisGuy's Avatar
Tighten those spark plugs 7-14 Ft/lbs.
OsirisGuy is right
2002 Mustang GT
Old 04-15-2009, 08:58 AM   #22
SaleenFiend's Avatar
To clear up a question while on the subject..
Is it better to change the plugs with a cold engine for a mildly warm? I have heard warm is usually better especially for aluminum heads?
Old 04-15-2009, 09:04 AM   #23
i know i did mine mildly warm and i know the new mustangs recomend that.
Old 04-15-2009, 11:22 AM   #24
OsirisGuy's Avatar
I thought it was the opposite for Alum. heads. When the heads are warm there is a higher risk of cross threading
OsirisGuy is right
2002 Mustang GT
Old 04-15-2009, 02:28 PM   #25
Well hopefully someone while chime in?
Old 04-15-2009, 02:33 PM   #26
I had heard the same thing that warm heads is bad for aluminum heads. not only for the cross threading risk but if the plug sticks it could rip the threads out and force you to have to helicoil them.
I change mine cold anyhow....I let it sit over night anyhow.
Old 04-15-2009, 02:44 PM   #27
Makes sense as the aluminum would be softer or even brittle when at higher temps.
Old 04-15-2009, 02:50 PM   #28
i try and let the car cool down as much as possible first. use anti-seize on all alum heads and i think its pretty much a non-issue.
iamdat is offline   Reply With Quote
Old 04-15-2009, 02:52 PM   #29
I use antiseize as well....but I don't push my luck....
Old 06-19-2009, 12:44 PM   #30
occhopperman27's Avatar
@ 60,000 miles mine looked darn near new, i really didnt need to change them out but i did anyway they had a lot of life on the factory motorcraft platinums
occhopperman27 is offline   Reply With Quote
Old 06-21-2009, 03:44 AM   #31
JoeyR's Avatar
Region: Oregon
Send a message via MSN to JoeyR
im currently using Autolight Double platinum's. very happy with quality.
2000 Mustang GT, SCT Tuner, K&N Cold-Air-Intake, BBK Short Throw, FR 3.73's, PaceSetter Longtubes w/3" streight pipe w/ resonators
JoeyR is offline   Reply With Quote
Spark plugs upton7 General Mustang Discussion 15 02-02-2010 02:00 PM
what spark plugs do i need fastfanatic 1996-2004 Mustang GT 6 09-14-2009 08:23 PM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 06:36 AM
Spark Plugs megax29 Pre-2005 V6 Mustang 20 10-09-2006 05:36 PM
Spark Plugs megax29 Pre-2005 V6 Mustang 13 03-25-2006 07:51 AM
05:07 AM
