2000 gt gears and tuner combo? - Mustang Evolution
Old 04-09-2009, 11:32 PM   #1
I just got a 2000 mustang gt 5 speed with flowmasters. I wanted to get the 3.73 gears and tuner kit from American muscle. Is this kit worth it and will it give me a noticeable gain in power. What other mods are a must. All post are appreciated.
pmushock is offline   Reply With Quote
Old 04-09-2009, 11:35 PM   #2
upton7's Avatar
Re: 2000 gt gears and tuner combo?
there will be no gain in horsepower from the gears but it will make it accelerate ALOT quicker i found the american muscle kit to be the cheapest deal
Old 04-09-2009, 11:39 PM   #3
are the gears in that kit good quality
Old 04-09-2009, 11:42 PM   #4
upton7's Avatar
ford racing is what i'm going to buy and that is what comes with it so yup
Old 04-10-2009, 12:37 AM   #5
Cobra GT's Avatar
+1 on the FRPP gears you are going to have to change the pinion bearing probably and need a new crush sleeve for the pinion so you just as well get the bearing kit and do your axle bearings while you are at it. I recommend the SCT Xcal 3 with the kits at AM I don’t think they offer it just the SF3. I would check with AM and see if they would sell you the Xcal 3 instead of the SF3 they are the same price. Good luck.
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 04-10-2009, 07:08 AM   #6
ford racing are probably the best gears to guy, gears usually dont break its the other parts that do. The ford ones are plenty strong for a DD car and occasional track car.
Install is a ***** expect 400 dollars for a good install for just the gears fyi.
A tuner is needed for speedo calibration but it wont do much of anything for power, but if you are going to do it go with a really good tuner, not just an off the shelf tune. Buy the tuner from whom ever you wish and then buy a tune from someone and load it on the car using the tuner. The only issue is to buy a tuner that the person you are letting tune the car can use.
Old 04-10-2009, 04:23 PM   #7
i have a friend who can do gears so the install will not be a problem but where would you buy tune for the tuner.
Old 04-11-2009, 04:43 PM   #8
Cobra GT's Avatar
You need to find a tuner in your area, or go to SCT's site and can locate one in your area.
SCT Automotive Performance Products
1996 GT (sold)
1997 Cobra
Want an 03/04 Cobra
Old 04-11-2009, 07:06 PM   #9
upton7's Avatar
if u go to a dealer and they make a custom one u won't need a tuner will u won't they have one
Old 04-15-2009, 10:03 AM   #10
SaleenFiend's Avatar
What you say?
Old 04-15-2009, 11:08 AM   #11
upton7's Avatar
Originally Posted by SaleenFiend View Post
What you say?
If you go to a shop that does custom tunes will you need a handheld tuner or will they have one that they can use?
Old 04-15-2009, 01:53 PM   #12
Herbstang's Avatar
You'll need a tuner .the shop just provides the tune to load into your tuner
Old 04-15-2009, 02:19 PM   #13
Depending on the shop they may make you purchase a hand held, but most do have the capability with out you purchasing a hand held tuner.
Break in for new gears?? SCT tuner to change speedo?? Camaro Eater Pre-2005 V6 Mustang 3 06-25-2010 07:03 AM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Tuner... Worth it or not? (2000 v6) CHILE10_STANG Pre-2005 V6 Mustang 13 10-29-2009 02:34 PM
2000 v6 gears and pulleys? CHILE10_STANG Pre-2005 V6 Mustang 21 07-27-2009 05:34 PM
what would this combo make? (HP?) notav8 Pre-2005 V6 Mustang 20 12-11-2003 11:23 AM
01:11 PM
