which oil filter - Mustang Evolution
Old 04-10-2009, 05:13 PM   #1
upton7's Avatar
which oil filter
wix k&n napa ? or other
Old 04-10-2009, 06:00 PM   #2
DarkShadows's Avatar
Re: which oil filter
wix, or motorcraft for me. k&n is overpriced for their oil filters
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 04-10-2009, 07:17 PM   #3
Scut95's Avatar
The motorcraft filter has a lot more filtration paper in it than the aftermarket brands. I run MC and you can get them at the regular car parts store for like $4-$5.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 04-10-2009, 07:39 PM   #4
upton7's Avatar
i heard the k&ns are reusable tho so after 3 oil changes you'd be even
Old 04-10-2009, 09:05 PM   #5
Motorcraft. If DangerDude was still around he'd give you a rubber hose beating for using K&N.
BTW...if you reuse a oil filter of any kind you are just asking for problems. They're cheap...replace them...with OEM.
Old 04-10-2009, 10:10 PM   #6
if you like the K&N buy a Mobil 1 filter, the only difference is the the K&N has a nut on the end.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 04-11-2009, 12:01 AM   #7
i chose to run motocraft on mine. i too believe the filtration on it is better than your others
less than stock engine, not running right, 40 series flows, steeda triax shifter
96cobra is offline   Reply With Quote
Old 04-11-2009, 08:06 AM   #8
no oilfilters are reuseable!!!!
Old 04-11-2009, 12:44 PM   #9
oem ford motorcraft, probably the best filter for the dollar spent out there no need to go elsewhere, it also has a drain back valve that you MUST use, I think the only other filter to have this is wix.
Old 04-12-2009, 11:50 AM   #10
1234's Avatar
I would say motorcraft or wix.
Old 04-12-2009, 05:16 PM   #11
jimmy_beaner's Avatar
Region: Iowa
I've ALWAYS used motorcraft... no issues. Just make sure you keep changing your oil and filter on regular intervals and you'll be dandy. There really isn't a better choice for the price.
Old 04-12-2009, 10:50 PM   #12
upton7's Avatar
i belevie from now on it'll be motorcraft or wix thanks guys
Old 04-13-2009, 11:53 AM   #13
SaleenFiend's Avatar
Originally Posted by DarkShadows View Post
Some oilfilters are reuseable!!!!
Pure Power Oil Filters High Performance Motor Oil
Fixed for you...
Old 04-13-2009, 12:17 PM   #14
Originally Posted by SaleenFiend View Post
i knew about the really expensive ones but i figured they didnt count in this discussion, i saw one for a mini a while back that was like $250 bucks. thats some bull**** right there. normal oil filters are too cheap to not buy those instead. you would have to change your oil 50 times before the filter would pay for itself. most people dont keep a car long enough to do 50 oil changes!
Old 04-13-2009, 12:23 PM   #15
Region: Iowa
the motorcraft one here is $3? 70 oil changes brings you to 210,000 miles... **** that
Old 04-13-2009, 03:23 PM   #16
I was rounding up
Old 04-13-2009, 03:49 PM   #17
Region: Iowa
I was rounding up
Still... who would want to use an oil filter for 150k miles when they are so cheap?
Old 04-13-2009, 04:05 PM   #18
I agree. Just to be clear I am not in favor of those filters just being the correction police. (I was haveing fun being an *******)
overheating after changing the oil filter adapter 2003stangmachI 1996-2004 Mustang GT 8 10-29-2009 08:26 AM
oil in air filter housing midnightrider_s Pre-2005 V6 Mustang 9 10-04-2009 07:19 AM
Yes i asking this, how do you properly re-oil a filter? Jrw4482 1979-1995 Mustang GT 12 05-14-2006 05:47 PM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 05:37 PM
03:14 AM
