squelll when turning right - Mustang Evolution
Old 04-17-2009, 01:24 PM   #1
BRIAN's Avatar
when i turn only right i get a squeeky noise ,cant tell if its the front or rear but its drivin me crazy!!Any thoughts of what it might be ita a 2002 gt.
BRIAN is offline   Reply With Quote
Old 04-17-2009, 01:46 PM   #2
hottcobra's Avatar
Re: squelll when turning right
any squeeking noise comming the suspension are from bushings.
First you need to figure out what corner of the car it's comming from. (may require someone outside the car and making turns in a parking lot to lisson to it for you)
once you find the general area it's comming from. you have bushions on the sway bars and the control arms. soake one bushion at a time down with WD-40 and drive the car. When you lube a certin one and the car stops making the noise. You have found the trouble maker and now you know what you need to change.
Most often I find that unless the car as over 100k miles it's usually one of the sway bar bushions.
Old 04-17-2009, 02:57 PM   #3
SaleenFiend's Avatar
Also, just in case your 'labeling' the noise incorrectly if your hearing a squeal check into your dust shields behind the rotors on both sides.
Old 04-17-2009, 03:38 PM   #4
hottcobra's Avatar
^tru dat More good advise above
Old 04-17-2009, 03:51 PM   #5
or it could be your seat squeaking. I know mine does that quite a bit. Look over me i'm drinking.
19Delta is offline   Reply With Quote
Old 04-17-2009, 03:56 PM   #6
You MUST post in the Drinking Thread or ELSE
Old 04-17-2009, 03:57 PM   #7
Already did
Weird sound when turning? SC_STEEDA Pre-2005 V6 Mustang 4 11-16-2009 06:36 PM
Turning of Overdrive, does it go into “Performance Mode”? Renegade 800 Pre-2005 V6 Mustang 13 06-27-2008 05:58 PM
Well well well England, you are turning into the country of the FATTIES Seph The Bar 10 02-28-2007 04:10 PM
Odometer Stopped Turning Brent Pre-2005 V6 Mustang 7 09-14-2006 09:24 AM
No turning back now... Bane- Pictures and Videos 5 05-19-2006 07:36 AM
05:43 AM
