I just put in my 3.73 gears - Mustang Evolution
Old 04-17-2009, 07:14 PM   #1
Questions is does the speedometer change my buddy who is a mechanic says it does? Those that have changed your gears already and have noticed any difference in your speedometer let me know.
tjzola is offline   Reply With Quote
Old 04-17-2009, 08:14 PM   #2
Region: Nevada
Re: I just put in my 3.73 gears
You should get a tuner to correct the speedo
chris098 is offline   Reply With Quote
Old 04-17-2009, 08:26 PM   #3
SaleenFiend's Avatar
you need either a speed calibrator or handheld tuner. By driving on 3.73s with stock programmed ratio you car odometer will calculate that you have driven further than you actually had because it will think you have gone 60 rather than 40mph. Your speedometer will also be off like 45mph(on speedometer):35(actual speed) or something similar
Old 04-17-2009, 11:41 PM   #4
upton7's Avatar
speed calibrator is 100 bucks and a tuner is 380 bucks but the tuner with make your car run even better but not 280 dollars the best thing is to get a custom tune
Old 04-21-2009, 02:17 AM   #5
BigDaddys Stang's Avatar
If you plan to keep adding bolt-ons a tuner will be better just do the math..
2000 Mustang V6 5spd
Cobra R front bumper, KR-S rear bumper 50% tinted windows.20in chrome wheels 245/35/20 Nankang & Falken profile tires, 4in chrome pipe.
Pioneer stereo & subs 2 12, Kenwood amp for spkrs, Sony X f subs. GT coming soon! moddedstangs & all fordstangs member.
BigDaddys Stang is offline   Reply With Quote
Old 04-21-2009, 06:12 AM   #6
Herbstang's Avatar
Good Advice !!
Old 04-21-2009, 09:19 AM   #7
some cars can use a speed cal unit (like dallas speed cal) it just plugs in between the sensors on the transmission and the ecu~ and alters the signal to fix the speedo~ my 01 used one. You will need to check if your specific year can use it. Its easy to install and is much cheaper than a tuner.
A tune is a great thing, but only 99+ can be fixed speedo wise from a tune~ and they are much more expensive so just an alternative to consider.
Old 04-21-2009, 10:34 AM   #8
Thumbs up Re: I just put in my 3.73 gears
Originally Posted by Herbstang View Post
Good Advice !!
Thanks buddy! just trying to do my best...
Old 04-21-2009, 04:36 PM   #9
I have gotten a free tuner from a shop in town. Thing is I made a choice of telling them their price was to high and they kept jacking my price up when I came to buy stuff. So, in other wordds You can find things for lower price and people to do for less and online, Now I I wont't go back there again for while. I will just go to Holcomb Motorsports which is 2 hous near me. And for the tuner I need to get the usb cable to upgrade my uner its the lower grade peice a **** one available they gave me this shop was NationalSpeed they tried the dirty tricks to get out free, I saw them look at all the tuners they took the cheaper one to give me ********. Hopefully None of them will see this post hahaha
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Please confirm which gears to put in my mustang 02mach6stang Pre-2005 V6 Mustang 29 06-20-2008 03:33 PM
not sure where to put this meteorachick The Bar 7 03-07-2005 04:54 PM
How much to put down?? StangGt804 The Bar 15 09-27-2004 06:13 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
10:14 PM
