2000 Mustang V-8 GT Automatic Convertable will not start - Mustang Evolution
Old 04-18-2009, 10:01 AM   #1
I have a 2000 Mustang V-8 GT Automatic Convertable that will not start. It will turn over and crank but not start. I have used starter fluid and it will then start and idle, if I try to drive it, it will accelerate but die when braking to a stop, needing starter fluid to get it going again. This continued as I went around the block.
I have changed out the fuel filters, new battery. I believe the fuel pump is working since it will run and rev once it is running.
I have had it attached to a computer and it could not find out or indicate any problems.
Any help or Advise would be appreciated
thechef is offline   Reply With Quote
Old 04-18-2009, 02:36 PM   #2
SaleenFiend's Avatar
Re: 2000 Mustang V-8 GT Automatic Convertable will not start
When you say you have attached it to a computer are you meaning that you used an OBDII scan tool to check for any DTCs (trouble codes)? Its possible you may have a Fuel Pressure Regulator issue or even a leak somewhere. Check around the injectors (they have o-rings that may be leaking) Have you performed any work on the vehicle recently?
Also, remove your spark plugs and check to see if you have any white residue/fuel/oil on them.
2000 mustang
Push to start for a 2000 blue-saleen Mustang Audio & Video 15 09-10-2009 10:33 AM
2000 mustang gt conv. want to modd dont knw where to start luvrobeer 1996-2004 Mustang GT 8 07-20-2009 12:54 AM
2000 V6 Green Automatic Stang too Ssstang New Member Introductions & Greetings 9 11-01-2005 07:55 PM
2000 V6 Convertable LOW MILES LIKE NEW FOR SALE Jays98Cobra Mustangs for Sale and Wanted 1 04-12-2005 02:51 PM
06:30 AM
