I'm RICH!!!! I'm RICH!!!! - Mustang Evolution
Old 04-22-2009, 09:01 PM   #1
Well, did some data logging tonight with my wide band finally....I think my tune may be a tad bit rich...what do y'all think? lol
****Disclaimer: The following 3rd gear pulls were done on an closed course at an undisclosed location in Mexico ****
ID:	20536   Click image for larger version
Old 04-22-2009, 09:04 PM   #2
hottcobra's Avatar
Re: I'm RICH!!!! I'm RICH!!!!
Old 04-22-2009, 09:06 PM   #3
hottcobra's Avatar
at least it's not under 10 like you thought
Old 04-22-2009, 09:13 PM   #4
Well, it's hard to say. It bottoms out at 10, so, it may be dipping below. It was nice to see a couple spots above 10 though...granted, only a few tenths, but at least it wasn't completely below.
I did manage to piss off a few people on the undisclosed closed road in mexico tho....but oh well, I gots my data. I'm pretty stoked that I am not pulling any timing at all. I mentioned in my post on the tunning forum it might not be a bad idea to add another degree to my street tune with minimal fuel changes. 19* timing should surely get me over 600 SAE on 93. I know there sure is enough fuel for it...and I am only 87% duty cycle on my fuel pumps, so I'm definitely good to go there.
Old 04-22-2009, 09:17 PM   #5
Cobra GT's Avatar
I'm unemployed/self employed can you help me, I need a 03/04 Cobra
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 04-22-2009, 09:19 PM   #6
hottcobra's Avatar
well did you send the data to RWTD
Old 04-22-2009, 09:20 PM   #7
Yeah, uploaded it after I did this thread.
Old 04-22-2009, 09:22 PM   #8
hottcobra's Avatar
cool. what's the turnaround on the tune?
Old 04-22-2009, 09:56 PM   #9
upton7's Avatar
whats this thread about
Old 04-22-2009, 10:00 PM   #10
hottcobra's Avatar
the air to fuel ratio on his car is very rich. meaning their is too much fuel being injected into his engine. right now his air fuel is at 10:1 a/f it should be around 11.5:1
Old 04-22-2009, 10:05 PM   #11
upton7's Avatar
what does the 10 stand for and what does the 1 stand for
Old 04-22-2009, 10:08 PM   #12
hottcobra's Avatar
it's a ratio 10 to 1 air to fuel ratio
Air-fuel ratio - Wikipedia, the free encyclopedia
Old 04-22-2009, 10:18 PM   #13
upton7's Avatar
i don't really get it can u explain it like this. Example : my gear ratio is 3.27 : 1 this means my driveshaft turns 3.73 turns for every time my tire does 1 full rotation
Old 04-22-2009, 10:21 PM   #14
jimmy_beaner's Avatar
Region: Iowa
10 parts of air to 1 part of fuel vs. 11 parts air to 1 part of fuel. It's a ratio... just like everything else. Fill in "part" with something else
Old 04-22-2009, 10:24 PM   #15
hottcobra's Avatar
exactly.
Old 04-22-2009, 10:24 PM   #16
upton7's Avatar
ok ic what is the "part" measured in?
Old 04-22-2009, 10:27 PM   #17
hottcobra's Avatar
particles of air
Old 04-22-2009, 10:28 PM   #18
upton7's Avatar
ok if there was a thanks button i'd use it that was pretty helpful thanks so a rich mixture is better?
Old 04-22-2009, 10:41 PM   #19
hottcobra's Avatar
on a s/c motor richer is safer. the lower the number the richer the mixture is. It's a fine line. leaner makes more power, but too lean makes motors go boom
Old 04-22-2009, 10:42 PM   #20
hottcobra's Avatar
now you can give thanks
Old 04-22-2009, 10:51 PM   #21
upton7's Avatar
Old 04-22-2009, 10:55 PM   #22
hottcobra's Avatar
I can't help it, I'm a thanks whore.
Old 04-22-2009, 10:57 PM   #23
upton7's Avatar
ha me 2 i want on the top list lol (that'll never happen)
Old 04-22-2009, 10:58 PM   #24
hottcobra's Avatar
well It's easy. just have no life and be on here 24/7
Old 04-22-2009, 11:03 PM   #25
upton7's Avatar
will do lol
Old 04-22-2009, 11:06 PM   #26
Wow, this thread blew up quick. lol
Yeah, I have way too much fuel right now. I would like to get closer to 12:1 like I was before my blower swap. 11.8 that the tuner was shooting for originally would be fine and would leave some room for bad gas...but I'd like to push the 12:1 line and get all I can out of it without it creating windows in the block.
Old 04-22-2009, 11:11 PM   #27
hottcobra's Avatar
I'd get 11.8 on the street tune and 12:1 on the race tune.
somebody's gotta keep up the slack while your gone
Old 04-22-2009, 11:18 PM   #28
I'll go for that kind of dialing in detail when I head over to his dyno this fall. If he can get me in the 11's A/F on my street tune I'll probably call it a day there...get through the summer, then get dialed in in the fall after the NY trip.
Old 04-23-2009, 07:40 AM   #29
SaleenFiend's Avatar
Yes! Have a job w/a computer and you can live on here! or a job with no work!
I missed alot last night... but I do realize for some reason I was thinking 10:1 was lean.... but I was just mixed up in my head.
Old 04-23-2009, 07:52 AM   #30
slostang's Avatar
Me personally I'd stick to 11.8. My race tune is between 11.5 and 11.8. What kind of timing were you seeing?
slostang is offline   Reply With Quote
Old 04-23-2009, 09:55 AM   #31
You also think you are spinning your tires on the dyno....
But yeah, my tune is commanding 18* of timing and that is what it is making and holding. It's nice seeing the car making the commanded amount of timing for a change. the 2.2 and lower intake port have my IAT2's down in the low 120s, high 1-teens consistently. With the eaton, I was in the mid-upper 130s so it would never use the full commanded timing.
Old 04-23-2009, 10:00 AM   #32
slostang's Avatar
well you are right, i'm not sure what it's doing on the dyno I just know when you put the numbers to the test, my rwhp doesn't add up to my weight versus trap speeds and e.t.'s.
Hi Rob
Old 04-23-2009, 10:18 AM   #33
let me know how you like rwtd, if its local its them or mph for me probably
Old 04-23-2009, 10:23 AM   #34
My brother used RWTD and was very satisfied, but he went SCT with Amazon this time after the Whipple. I will be using RWTD or Rick probably also.
Old 04-23-2009, 10:23 AM   #35
RWTD was great the first time I used them, and I'm sure they will be great this time around. I did their email tune for the time being to get the car safe for the summer and then I'll go there in the fall.
Woooo I'm gonna be rich! Seph The Bar 7 03-17-2007 12:39 AM
Do u have rich parents MusclesFromBrussels The Bar 28 10-23-2003 09:07 PM
01:17 AM
