Door Lock Trouble - Mustang Evolution
Old 04-24-2009, 11:41 AM   #1
Door Lock Trouble
When I got my 2000 gt two weeks ago, the guy who sold it said the passenger door lock was starting to die. I woke up this morning and both door locks did not work. Checked the fuses and the remote, both are fine.
I need help
pmushock is offline   Reply With Quote
Old 04-24-2009, 12:35 PM   #2
Re: Door Lock Trouble
does the key work when you put it in? If it does not then its the linkage to the lock mechanism~ if the key lock works and the remove does not work then it can either be the box in the trunk that gets the signal, or the actuator that makes the lock open~
Old 04-24-2009, 12:51 PM   #3
where is the box in the trunk? the key works.
Old 04-24-2009, 04:26 PM   #4
do you hear the door lock actuator on that side? if not, check teh switch itself to see if its delivering power to the actuator. if not, remove door panel and check power at actuator. 6L3Z-25218A42-AA is the part number to the passenger side actuator/llatch assy.
iamdat is offline   Reply With Quote
Old 04-24-2009, 08:16 PM   #5
the only sound is under the dash. Both don't work so could it be just the one actuator or both?
need help changing door lock cylinder on my 98 dvon1981 The Bar 7 09-25-2006 03:20 PM
Sprayed in bedliner and billet fuel door with lock... Rick0636 The Bar 21 08-06-2005 11:42 AM
t-lock gforces69 Pre-2005 V6 Mustang 3 08-24-2004 06:53 PM
door lock problems WhiteStang99 Pre-2005 V6 Mustang 9 04-06-2004 04:36 PM
09:13 PM
