TIMING HELP!?!? - Mustang Evolution
Old 04-24-2009, 08:31 PM   #1
timeformiller44's Avatar
TIMING HELP!?!?
hey, just put a set of comp cams in my car, timed it and its of just a little bit bc its hitting just a little..but compression is good and leak down test is good so nothing got bent so i want to re time the cams..and i went on crap diagrams and such..anyone have a REALLY good step by step on how to time with pictures and that.. so i can make it PERFECT.. it has 70K so i wonder if i should put new chains on it, because i hear maybe old ones can stretch a little and seeing as the cams are high lift it make be right timing, just hitting bc chains are stretched??
specs:
Gross Valve Lift: Intake/.550 Exhaust/.550
Cam Lobe Lift: Intake/.3000 Exhaust/.3000
ADV. DUR @ .050 Valve Lift Intake/270 Exhaust 274
please any good help would be appreciated!!
timeformiller44 is offline   Reply With Quote
Old 04-27-2009, 09:49 AM   #2
Re: TIMING HELP!?!?
anyone???
Old 04-27-2009, 10:05 AM   #3
Re: TIMING HELP!?!?
theres gold links (actualyl bronze looking) that are 180degree from eachother. they should sit on the dot on the cam gear and crankgear. its gonna be hard to see the backchain on the dot so you're gonna have to use a mirror to see it. on these newer engines, its really not too nessesary to change timing chains. on old pushrod stuff it is though
iamdat is offline   Reply With Quote
Help with spark timing Rawdawg440 1996-2004 Mustang GT 2 07-20-2010 12:06 PM
3.8 timing marks. Foxone Pre-2005 V6 Mustang 0 05-26-2010 06:43 PM
Timing is off!!!! ballajb 1979-1995 Mustang GT 2 10-28-2009 02:09 PM
Q about setting timing Z-EATER General Car Discussion 1 04-04-2008 08:03 AM
timing problems on 94 3.8 eagle05 Pre-2005 V6 Mustang 7 11-26-2007 07:00 AM
10:33 AM
