engine issues... no codes... fuel pump video added - Mustang Evolution
Old 04-26-2009, 08:21 AM   #1
jimmy_beaner's Avatar
Region: Iowa
My motor acts up somewhat randomly. All day yesterday it ran perfectly. Then, this morning... it randomly (on acceleration) feels like it's stuttering, or like traction control is kicking on. Part of me feels like it could be a vacuum leak. I replaced the passenger side PCV tubing because it had developed a hole.. and that seemed to fix most of the problem. The car has 133k miles on it now. Does anyone have any ideas on what else it might be? I'm throwing no codes. Also, the motor isn't making any "weird noises", no ticks... just stutters randomly.
Also, my clutch pedal vibrates a decent amount some times. I'm not sure if it's from my stock clutch having a fair amount of wear on it or what the deal is. Still holds power just fine, not slipping at all.
Old 04-26-2009, 12:10 PM   #2
Re: engine issues... no codes
maf? if its not clean and can run rough~
Old 04-26-2009, 01:36 PM   #3
Region: Iowa
MAF is brand new.
Some more info... when not into the throttle (i.e.... gaining speed like a minivan), the car runs fine... when getting deeper into the throttle than just grandma acceleration... the car has issues. It stutters under acceleration. When letting off the throttle, when you reach the "almost off" point, it goes back to running like normal.
It sounds almost like there is a hole that opens up when the car is under load... and that causes the car to have the power killed.
Old 04-26-2009, 02:39 PM   #4
Region: Iowa
I'd say it could be fuel related... I'm gonna go check it out some more right now
Old 04-26-2009, 05:44 PM   #5
Region: Iowa
Old 04-26-2009, 06:02 PM   #6
Region: Iowa
Re: engine issues... no codes... fuel pump video added
not sure what happened to the sound... but this is pedal to the floor... in 3rd?
Old 04-26-2009, 09:05 PM   #7
Region: Iowa
went ahead and got a SVT Focus Fuel pump... should be shipping out tomorrow. I'm also planning on getting an SCT XCal 3. I'm curious to see if this finally fixes my issues. If so... I can't wait to have a functioning car again. (even though I've been driving the car 12 hours the last 2 days)
Old 04-26-2009, 09:13 PM   #8
upton7's Avatar
sorry to get off the topic man but are those guages any trouble to put in?
Old 04-26-2009, 09:15 PM   #9
Region: Iowa
nope... pretty easy. Just have to swap over the odometer cluster... very easy.
Old 04-26-2009, 09:17 PM   #10
upton7's Avatar
i might have to do that then
Old 04-26-2009, 10:56 PM   #11
make sure u change the fuel filter while u change the pump.
96 GT- Who knows what's in it.
Old 04-27-2009, 05:50 AM   #12
Region: Iowa
that's what the puddle of fuel on the ground is. I may change it again though. I'm thinking of cutting that god damn metal screw strap. **** that thing. I have a bag of 100 zip ties... that'll do just as good of job, and I can cut the bastards off after I use them.
Old 04-27-2009, 01:27 PM   #13
hey you have the same problem i got lemmi know how you fix it.
eddie1 is offline   Reply With Quote
Old 04-27-2009, 01:37 PM   #14
Region: Iowa
I'm gonna replace the fuel pump
Old 04-27-2009, 02:46 PM   #15
well after reading all the posts it seems your not sure if it is.....
Old 04-27-2009, 02:58 PM   #16
DarkShadows's Avatar
Hes right you know. damn yankee beaners
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 04-27-2009, 03:17 PM   #17
Region: Iowa
well it's always been a fuel problem it seems...
up to like a month ago or so... the car had random acceleration issues/hesitation under high load... and it developed into a worse and worse issue. I thought it was a vac leak for awhile, but I spent 5 hours looking for vac leaks. It makes sense that it is the fuel pump. And the misfire blinking check engine light this morning supports a weak fuel pump notion as well.
Old 04-27-2009, 03:18 PM   #18
not be ignorant but could you give me more info on yuor problem and how you fixed it? For what it seems yuor car is doing exackly what mine is right now were it has absolutly no power in any gear and takes a arm and leg to get going......and does it like studder when u give it gas in nutral and when in gear it acts like only half motor is working
sorry for any inconvience but im very interested due to I can't send my car out to have some fix it.
Old 04-27-2009, 03:23 PM   #19
Region: Iowa
I haven't fixed it yet... I ordered a new fuel pump last night. I will drop the tank and put the new pump in when it gets here... and that should fix the problem.
The car felt like traction control was engaging when I drove it. But it wasn't.
Old 04-27-2009, 03:28 PM   #20
i don't have TC but the car jerks like it trying to go but only half motor is working and it went from working fine untill the car warmed and it in about 3 days the car did the studdering right when on start up.....i hade people telling me it was the timing,fuel pump.
the car only has 90K miles and i run my gas like red line most of the time due to money n being broke so could that eventualy fry the pump? any way to test this before i buy a $120 fuel pump you know
Old 04-27-2009, 03:29 PM   #21
Region: Iowa
... change your fuel filter. When you run your gas so low, all the **** that's in your tank gets sucked into the filter.
Old 04-27-2009, 03:30 PM   #22
ok ima do that right now and get back to you.
also were is the fuel filter at?
Old 04-27-2009, 03:32 PM   #23
Region: Iowa
it still may be something else... but the filter is the first place to start. It sounds probably like the fuel pump may be having issues. You should be able to check with AutoZone about renting a fuel pressure gauge for the schrader valve, and then you can see what kind of pressure your pump is providing.
Old 04-27-2009, 03:43 PM   #24
ok i'll more than likely do that tonight and let you guys know
but were is the filter located? for I have my buddy bringing me one now from advanced
Old 04-27-2009, 03:50 PM   #25
hmm sounds like a fuel problem to me too. mi fianlly got to hear the video too lol.
Old 04-27-2009, 04:05 PM   #26
Region: Iowa
go under the car, you'll need a fuel line disconnect tool. Then, it's tucked up between the differential and the fuel tank.
I'm hoping it's just the fuel pump... I sure hope so
Old 04-27-2009, 09:15 PM   #27
ok so replaced the filter with no luck so I went to the boys at autozone rented there $150 fuel pressure kit and eletric meter thing.....fallowed everything to the T in the manual and the fuel press sure at idle is 30psi exackly(average rang is 30-45psi according to manual) and when rev'd up it goes to around 43psi top...n all the injectors read the same(i did all tests twice both pressure and eletric). The car still studders and has better power but still acts like its a 4 cylinder honda and putters around.
all plugs good, good gas, doesn't over heat, has normal oil pressure.....so I dunno what to do next any help?
Old 04-27-2009, 11:21 PM   #28
^coil packs.
Old 04-28-2009, 05:05 AM   #29
^coil packs.
nope got them tested to they all check out and are at the peak perforamnce limit.
Old 04-28-2009, 05:56 AM   #30
Region: Iowa
well that frightens me for what it might be for the GT... hahaha. I am really hoping that I don't have to buy another car until summer...
Old 04-28-2009, 12:19 PM   #31
Send a message via AIM to Matt GT
Compression test???
2003 Zinc Yellow Mustang GT
(Bone *** Stock)
Matt GT is offline   Reply With Quote
Old 04-28-2009, 12:31 PM   #32
Region: Iowa
I'm gonna try the fuel pump first... my second strategy will be a second car hahaha
Old 04-28-2009, 01:41 PM   #33
this thing needs to be properly diagnosed. if you lived closer, i would be able to help you.
iamdat is offline   Reply With Quote
Old 04-28-2009, 04:16 PM   #34
Region: Iowa
yeah, that's all well and good... but I need to get the car fixed and running. I am limited in tools and what-not. But I'm hoping the fuel pump solves the problem. How much does a compression test cost?
Old 04-28-2009, 04:26 PM   #35
well took the car to ford(costs arm and leg ugh) and they told me it's more than likely the timing and so did some other mechanic.......now it's still at ford they looking at it tomarrow but if say the timing is off they said it only takes a program on the computer to change it and yet another guy says you have to freaking tear the hole front of the motor off to get to the 2 chains.....what ones right for i know one is $$$$ and the other way ford said would take 30 seconds and $80
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Fuel pump issues! Can anyone help? Stangbaby302 1979-1995 Mustang GT 5 04-13-2008 12:44 AM
Fuel pump lowflyn Mustang Parts for Sale and Wanted 4 08-01-2006 08:12 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
fuel tank and radiator issues... mustangmare Pre-2005 V6 Mustang 1 11-01-2004 07:09 PM
06:32 AM
