starter on a 2001 cobra - Mustang Evolution
Old 04-26-2009, 07:19 PM   #1
zack1134's Avatar
Question starter on a 2001 cobra
im trying to change the starter on my friends cobra and am a little perplexed as to how i can reac the top bolts anyone who has done this and knows a trick it would be greatly appreciated thank you
2000 GT 5 spd ,cai with k&n filter,3.73's,Diablosport predator tune,slp loudmouth cat back,more to come
zack1134 is offline   Reply With Quote
Old 04-26-2009, 10:30 PM   #2
upton7's Avatar
Re: starter on a 2001 cobra
if i could see it i could tell you post a pic or wait for someone who has done it i don't know what it looks like
Old 04-26-2009, 10:43 PM   #3
a ****load of extensions and a swivel is your friend lol. that top bolt is a beast but it can be taken off. have one guy under the car watching the socket and guide it on and hold the socket on the bolt, then the other will be operating the ratchet. it can be a one man job, ive done it before, but its easier with two. as far as putting it back in, all u need is 2 bolts holding it in, the earlier 4.6 castings only had 2 bolt mounting the starter on, and in 96 they went with 3.
96 GT- Who knows what's in it.
Old 04-27-2009, 06:59 AM   #4
SaleenFiend's Avatar
I swapped mine with hardly any problems... Just be patient and determine what you need to catch the bolt before you start getting aggravated, took me like 15 mins. Also, I did not use a swivel on my 01 Cobra.
Old 04-27-2009, 08:24 AM   #5
yea finding the right angle and the right set of extensions etc can make it all easier
Old 04-29-2009, 03:36 PM   #6
zack1134's Avatar
ok i have good news and bad news the good news is that i got the starter swapped out and that top bolt was a beast anyway the car still wont start it isnt the battery just put new one in but it still just gives one click when you turn the key any ideas on what it could possibly be
Old 04-29-2009, 04:30 PM   #7
there is a bad connection somewhere. check terminals, etc.
Old 04-29-2009, 09:09 PM   #8
Cobra GT's Avatar
and the starter wires
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 04-30-2009, 09:30 PM   #9
zack1134's Avatar
i have now triple checked everything even replaced the ignition switch and still all i get are clicks i guess it could be possible that the brand new starter is no good
Old 05-04-2009, 07:38 PM   #10
do the guages and all lights stay on when you try to start the car? or do they go off after the click? It sound's like something in the ignition circuit is grounding.
-Daniel
2000 Vert, 4.6 SOHC swap, old set-up intercooled s-trim @11lbs..New setup-5.0 stroker, stage 2 heads, kenne bell 2.2l with a 2.75"
daniel302 is offline   Reply With Quote
Old 05-04-2009, 08:10 PM   #11
Cobra GT's Avatar
Try jumping the starter with a screw driver and maybe tapping on it with a hammer, the bendix may be stuck.
1996 GT (sold)
1997 Cobra
Want an 03/04 Cobra
1999 Cobra VS. 2001 Cobra jimmy_beaner The Bar 42 08-24-2008 10:57 PM
12:13 PM
