4.6 and 5.4 - Mustang Evolution
Old 05-03-2009, 09:48 AM   #1
Question 4.6 and 5.4
ok so i have a 98 gt with a 2001 ford lightning 5.4 engine in it
what i need to know is what is the same on the 5.4 and 4.6 ive heard the heads and stuff is there anything else ? im needing some headers and other stuff help
o and if they are the same on some stuff what year 4.6 would i order stuff for like a - - - - year 4.6?
blackgtman is offline   Reply With Quote
Old 05-03-2009, 10:46 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: 4.6 and 5.4
isn't the lightning a 4v? If so, you will require 4v heads. Which means a lot of the interchange parts will be for the Cobra motor, not the 2v GT motor.
Old 05-03-2009, 05:46 PM   #3
Re: 4.6 and 5.4
the lightning motor is actually a 2v motor, the 4.6 heads will bolt up with no problems. there are no production headers made to fit the 5.4 motor in a mustang, u can get shorties and make them work with a little modification to the mid pipe. the heads are pi heads on the lightning, any aftermarket heads that bolt up to the 4.6 2v will go on the 5.4 2v. however the intakes will not swap over due to the difference in width between the 2 motors. all electronics will bolt up fine.
96 GT- Who knows what's in it.
Old 05-04-2009, 07:24 AM   #4
Re: 4.6 and 5.4
what kind of hood are you having to run
11:43 PM
