Just ordered my first upgrade - Mustang Evolution
Old 05-04-2009, 07:26 PM   #1
upton7's Avatar
I ordered a BBK Xpipe for my 02 gt i'm putting it in myself but i had a couple questions. First how do i take out the o2 sensors not the harness but the part that actually goes in the pipe. Second i know i need mil eliminators where can i get them. (american muscle has em for 60 bucks i was wondereing if someone saw some cheaper)
Old 05-04-2009, 07:52 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Just ordered my first upgrade
02 sensors unclip, and then unscrew. I'm not sure on the MIL eliminators... I got them there... if you had a tuner you could just shut them off
Old 05-04-2009, 08:10 PM   #3
upton7's Avatar
thanks man anything else i should look out for?
Old 05-05-2009, 05:58 AM   #4
Region: Iowa
be careful on them, make sure all the o2 sensors are disconnected before you start taking the stock midpipe off. o2 sensors are expensive to replace. Other than that... you should be good. You may consider taking the $60-ish for MIL's and put that towards a tuner... it's like a discount lol.
Old 05-05-2009, 07:22 AM   #5
MIL eliminators are usually good for a while but go out~ so FYI you may need a tune down the road to remove the CEL light for those~ consider them a temporary fix.
Old 05-05-2009, 08:55 AM   #6
Region: Iowa
yes, mine "went out" and then magically started working. Tuner took care of it for good
Old 05-05-2009, 09:01 AM   #7
WORD, get a tuner.
iamdat is offline   Reply With Quote
Old 05-05-2009, 09:49 AM   #8
upton7's Avatar
will a sct tuner with american muscle tune remove the light?
Old 05-05-2009, 09:49 AM   #9
upton7's Avatar
will it hurt nething if the light is on and i don't tune it yet?
Old 05-05-2009, 10:14 AM   #10
hottcobra's Avatar
yes your car is not gonna run correctly. It's gonna think the engine is running and the cats have went bad.
As far as taking the stock cats out. It makes it a lot easier if you spray the bolts with WD-40 of the like before you try to brake them loose.
Old 05-05-2009, 12:28 PM   #11
Region: Iowa
the tuner will remove the CODES, not just the light. It shuts off those sensors all together.
I doubt it would be good to run around with the light on.
yeah, or penetrating oil. Just pray to God you don't have one rust welded in like I did. They welded a nut to it and everything and it wouldn't move. Ended up plasma torching it out
Old 05-05-2009, 06:04 PM   #12
upton7's Avatar
so if i get the tuner the code will not come back?
Old 05-05-2009, 08:22 PM   #13
Region: Iowa
nope, the tuner kills the code for good... and you can turn off your traction control too
Old 05-05-2009, 10:10 PM   #14
upton7's Avatar
will one of those computers from a shop clear it for good or will it come back
Old 05-06-2009, 06:08 AM   #15
Region: Iowa
if you get tuned, they should be able to do it as well
Old 05-06-2009, 02:45 PM   #16
upton7's Avatar
they can't tune it just reads and clears codes but some say it will come back
Old 05-06-2009, 03:06 PM   #17
slostang's Avatar
It will come back unless they are disabled in your ECM. You need a handheld tuner to do this.
Hi Rob
slostang is offline   Reply With Quote
Old 05-06-2009, 04:23 PM   #18
SaleenFiend's Avatar
A hand held or tuner is only turning off the rear 02 sensors and the monitoring system along with it. As if you have no rear 02s.
Old 05-06-2009, 05:37 PM   #19
upton7's Avatar
this ****in sucks
Old 05-06-2009, 06:15 PM   #20
Region: Iowa
just save up and get an SCT XCal 3... I wish I had bought it forever and a day ago.
Old 05-06-2009, 08:08 PM   #21
upton7's Avatar
i'm just frustated by vehicle computers
Old 05-06-2009, 10:12 PM   #22
upton7's Avatar
would this work?
eBay Motors: 02 CEL / MIL CHECK ENGINE LIGHT ELIMINATOR SENSOR (item 320348561865 end time May-08-09 22:54:37 PDT)
Old 05-06-2009, 10:19 PM   #23
hottcobra's Avatar
yeah. but you would still do better with a tuner
Old 05-06-2009, 10:21 PM   #24
upton7's Avatar
i will eventually get a tuner but with that keep the light off for a while? and make my car run decently?
Old 05-06-2009, 10:42 PM   #25
hottcobra's Avatar
they should work fine.
Old 05-06-2009, 11:17 PM   #26
upton7's Avatar
do u think those will fit my car it doesn't specify on the page
Old 05-09-2009, 12:19 AM   #27
upton7's Avatar
well i'm putting the x-pipe on and it seems like the o2 sensor wire won't reach the harness it's like right there do i need an extender? Or will the green harness pop off the body so it can reach a lil farther?
Old 05-09-2009, 02:06 AM   #28
upton7's Avatar
ok i got the o2 sensors to connect and i got everything on it doesn't really sound right. I think there may be an exhaust leak. If there is how can i find out where it is?
Old 05-09-2009, 07:47 AM   #29
Well, I mean, I just know what an exhaust leak sounds like. You shouldn't hear any noise coming from around the xpipe, all of the noise should exit from the rear.
The most common exhaust leak on our cars comes from the pass side where the little 'donut' gasket is. I always work the x pipe up in the best possible position and kinda tighten each bolt a little at a time and wiggle the x pipe into position often in order to make sure it stays snug. If you cannot get the gasket to stop leaking try a high temperature gasket maker around that gasket or a new one. If you continue to have issues have a shop look at it and fix it for you as it probably won't cost much at all.
Old 05-09-2009, 11:03 AM   #30
MonteCitan's Avatar
I also say go for a tuner.. Buying 2 02 simulators would bring you 1/3 of the way to cost of the tuner as it is
I'm not sure how big a part it played, but just shorty headers and off the shelf tune my car went from trapping ~95 to trapping 99.98 MPH in warmer weather (was an 02 GT)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-09-2009, 12:10 PM   #31
upton7's Avatar
OK, I'm pretty sure the leak is on the driver side where the downpipe bolts to the exhuast manifold. The bolts are as tight as they will go. This the the pipe where the metal thing that the bolt goes throught can move up and down is it possible its making t hat clicking sound out of the o2 sensor if i didn't get it tight enough?
Old 05-09-2009, 10:41 PM   #32
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I didn't read every single post cuz I'm lazy right now, but try getting a squirt bottle and spray water where you think you might hear the leak coming from. look for bubbles.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 05-09-2009, 10:52 PM   #33
Otlaw80's Avatar
You can also have someone cover the tailpipes (with a rag or gloves) while you are under the car. You will be able to hear the leak loud and clear (sounds like air rushing out). And as someone said previously, make sure u used a new "donut" gasket and tighten each bolt little by little to draw the flange up evenly.
Old 05-09-2009, 11:26 PM   #34
upton7's Avatar
OK. The leak is in the downpipe the pipe wasn't flanged enough so i'm taking it to a guy to fix it and put the downpipe back on.
Old 05-10-2009, 11:44 PM   #35
How did you find it? so other people can learn from this....
Ordered first Modification:Many to come jwalthersoccer Pre-2005 V6 Mustang 11 12-12-2009 10:00 AM
New parts ordered SaturnMan8227 Pre-2005 V6 Mustang 10 02-06-2009 08:03 PM
Just ordered My New Procharger GT-Eater Pre-2005 V6 Mustang 46 01-03-2006 02:31 PM
just ordered... dark The Bar 12 05-16-2005 07:34 PM
01:20 PM
