Steeda tri-ax - Mustang Evolution
Old 01-19-2005, 06:29 PM   #1
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
Steeda tri-ax
What is the easiest/best way to get the stock shifter out from the seal?
I have it all unbolted but the seal just will not break to take it the rest of the way off.
19ClearCobra96 is offline   Reply With Quote
Old 01-19-2005, 06:40 PM   #2
Send a message via AIM to v6stangracer
i think when i did mine it just took some brute force, i think somehow i pryed it off a little but i dont remember for sure, good luck tho
v6stangracer is offline   Reply With Quote
Old 01-19-2005, 09:14 PM   #3
Region: Nebraska
got it just took some tugging
Old 02-20-2005, 12:08 PM   #4
I have had the same issue on a few Stangs. The way to break the seal of a stock shifter is fairly easy. Take a 3 to 4 foot 2X4 and place it at the base of the shifter. Then, with one quick blow (I used a rubber mallet) off she'll come. Don't forget to scrape off the old gasket sealant, and reseal it with a high temperature gasket sealant.
WhiteThang is offline   Reply With Quote
Old 02-21-2005, 04:08 PM   #5
you gots to pull... try to pull straight up so all you hurt is the shifter... and make sure the little rubber thing goes back the hole where the shifter ball slides into.
Steeda tri-ax tr3650 spooky Mustang Parts for Sale and Wanted 3 01-12-2007 08:00 AM
steeda tri-ax shifter electricstang Pre-2005 V6 Mustang 15 09-25-2005 08:57 PM
steeda tri-ax 1997grnstang Pre-2005 V6 Mustang 10 02-16-2005 08:27 PM
Steeda tri ax t5/45 QuikStang01Lx Mustang Parts for Sale and Wanted 2 12-06-2004 02:28 PM
*GP* Steeda Tri-ax QuikStang01Lx Mustang Parts for Sale and Wanted 1 12-05-2004 11:41 PM
04:30 PM
