running bad help please - Mustang Evolution
Old 05-09-2009, 10:04 PM   #1
i got a 1999 3.8 liter when i crank it up i have to give it gas if i dont it want start when i do get it started when i give it gas it rattles on the to end (it sounds like the top) i put a water pump/ o2 cesors/checked the pivot and rockers i put it on the computor it says bank 1 and 2 .... can this be from cats or what i also put on coil pack wires and plugs some one please help dont no what to do !!!!!!!!!!
scott3.8stang is offline   Reply With Quote
Old 05-09-2009, 10:59 PM   #2
Otlaw80's Avatar
Re: running bad help please
What did the computer say about bank 1 and bank 2? Cat's will rattle if they are starting to break up inside, could be causing restriction. If u have a scanner u can check the datastream on the O2 sensors. Upstream(before cat) voltage should be changing up and down,the downstream (after cat) should be pretty steady. If the downstream is changing up and down it usually means the cats are not doing there job and can cause car to run rough(or not start when it gets real bad)
Old 05-09-2009, 11:10 PM   #3
it just says bank 1 and 2 thats all im going to get a scanner and see if thats the problem it sounds like the rattel when i hit the gas is coming from the top do you think that is also from the cats ?????thanks for all te help
Old 05-09-2009, 11:12 PM   #4
Otlaw80's Avatar
without hearing it, its hard to tell. Exhaust sounds tend to transfer all over. If possible u can jack up the car and hit the cats(with your hand) and if they are broken up inside you will be able to hear them rattling.
Old 05-09-2009, 11:14 PM   #5
thx
95 GT running bad wvstang5.0ho 1979-1995 Mustang GT 6 08-23-2008 10:50 AM
94 95 5.0 running bad quiting or won't crank cheep fix inside eagle05 1979-1995 Mustang GT 0 05-01-2008 09:57 PM
Hillarys such a bad bad girl.... Brent The Bar 24 03-31-2005 04:41 PM
running from cops is bad....... mmmmkay? .:DarkEntity:. The Bar 10 10-11-2003 12:14 PM
03:22 AM
