1996 GT Stang engine swap with.... - Mustang Evolution
Old 01-24-2005, 08:08 PM   #1
Send a message via Yahoo to cagedthought
I was wondering if a 1996 MUSTANG GT 4.6 LTR MOTOR with a 2001 5 SPEED TRANSMISSION TREMEC WITH CLUTCH will fit into a 2001 V6 Stang Convert. ?
anyhelp will be appreciated.
James
James
cagedthought is offline   Reply With Quote
Old 01-24-2005, 10:48 PM   #2
Well, I'll go ahead and say it because I know it will get said... With enough money, you can do anything. Thats about all I can say on this subject, and that I know it won't be cheap because you also have to look at suspension, rear axle, computer, ect. ect. Someone else will come in here with more knowledge on the subject.
Old 01-25-2005, 08:34 AM   #3
They will mount together. The 96 4.6 liter engine won't put out very much power though is the only problem.
Old 01-25-2005, 05:35 PM   #4
Just get a 2001 GT motor, if you cant just get the 96 motor & do the p1 head swap later. Or even better get some ported patriot heads.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 01-25-2005, 05:35 PM   #5
It will have alot more torque then the motor that came with it, even if you don't do the head swap.
Old 01-25-2005, 06:34 PM   #6
if its a gr8 deal roll with it but prolly has high miles on a 96. if it does its not worth it and if you arent doing the swap your self id just save for a newer (less milage) motor cause you dont want to have to rebuild it. you can always make it fit but im not sure of what all it would take
cjd10 is offline   Reply With Quote
Old 02-21-2005, 10:14 AM   #7
He is right it prolly has high miles.
Old 03-02-2005, 02:05 AM   #8
silverstangboy's Avatar
yeah it'll work, no cutting or welding... but again, unless your going to mod the engine (headswaps) I wouldn't go to all the trouble, if you could get your hands on a 4 vavle though, yeah i'd do it or at least a newer 4.6... as far as money goes you'd be better to sell yours and buy a newer car, if you wanna learn alot, then do the swap, cause it comes out about equal, or close enough (not counting labor)
and this is coming from a guy that did a total 4 cyclinder to v8 swap in a fox body, a car thats actually easier to swap parts in and out, not to meantion I went from auto to manual too.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-25-2005, 07:22 AM   #9
I beg to differ
AlmostN8 is offline   Reply With Quote
Old 03-25-2005, 07:28 AM   #10
You will have to do futz around with the wiring harnesses as well. Ported 96 heads will flow better than PI heads. My new motor im building is as follows
95 crown vic block
vic crank
pistons and rods from a 2004 4.6
96 heads (ported)
99 PI cams
ported 2004 Plenum
Should be a nice motor when Im done. Main problem you will have is wiring issues though.
Old 03-25-2005, 09:53 AM   #11
RGR
Send a message via AIM to RGR
Agreed, the 96-98 heads are true 4.6 heads and the PI heads
are 5.4 heads with HUGE ports compared to the 96-8's, which
flow more (ported) than PI heads (stock) and with much higher velocity!
The rest of your combo looks nice Almost
You've probably seen this but I'll link it here for the others:
4.6 cylinder head info:
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-28-2005, 08:25 AM   #12
Yeah as you sayin there Im gonna go ported with PI cams and replace the 96-98 pistons with a set of new 04 dished. should be a nice combo. Now I just gotta finish building the wifes car and I can worry with mine lol.
Old 03-28-2005, 08:27 AM   #13
I beg to differ
I was talking about if you don't mod it...I keep up with if not pass stock GT's
1996 V6 to V8 engine swap. deere291 Pre-2005 V6 Mustang 2 04-09-2010 10:21 AM
1996 v6 swap Kelo Pre-2005 V6 Mustang 0 06-02-2008 08:05 AM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
1996 Mustang 3.8 to swap to 1999- 2004 3.8 NewkidonDblock Pre-2005 V6 Mustang 5 05-30-2006 09:17 AM
1996 V6 Stang for Sale on Ebay robert0803 Mustangs for Sale and Wanted 5 05-20-2005 07:32 PM
12:10 PM
